Just connected at 16mb/s ... Now up to 22mb/s (Value) 462 metres from Exchange
- Re: Just connected at 16mb/s
- « Previous
- 1
- 2
- Next »
03-07-2011 3:45 PM
Quote from: PlusComUK Upstream increase not for me I'm afraid.
Spoke to a very knowledgable and nice technical chap, and by increasing my upstream, I lose some downstream speed.
Ring plusnet ask them how much you would lose. If you do have you upload speed uncapped and you lose too much download speeds they will change it back for you. Its not set in stone
Puddy
ps you will find the level of expertise on this site very good
Message 16 of 24
(517 Views)
03-07-2011 3:49 PM
Quote from: Baldeagle1 BT's Infinity checker said Fibre wasn't even planned for my area in the next 6 months!
Paul.
Hi paul
How did you find out fibre was availble if its not listed I would hate to miss out?.
Although because I am so close to my BT exchange and my line goes direct in to it their no BT cabinet inbetween so I may lose out on fibre
puddy
Message 17 of 24
(517 Views)
Re: Just connected at 16mb/s ... Now up to 22mb/s (Value) 462 metres from Exchange
04-07-2011 1:11 AM
Message 18 of 24
(517 Views)
04-07-2011 2:03 AM
Thats an impressively steady graph !
Not bad at all.. I Personally, would have the US uncapped too.
But thats just preference
Message 19 of 24
(517 Views)
04-07-2011 3:37 AM
Quote from: puddy
Paul.
Hi paul
puddy
It was shown on Plusnets website in the phone No. checker in the Fibre Optics Arrives section
Message 20 of 24
(517 Views)
04-07-2011 5:55 PM
Quote If you do lose downstream speed when having the upstream uncapped (very unlikely, as upstream and downstream use different frequencies
Jaggies, could this speed loss be down to having interleaving turned off then ?
I have read on a few forums that sometimes on ADSL2+ if you have interleaving turned off, then your line gets capped at a speed way less than what you should be getting.
Message 21 of 24
(517 Views)
04-07-2011 6:40 PM
I haven't heard of that, but anything is possible. I don't think Interleaving can be turned off completely on ADSL2+, but the depth of Interleaving can be increased or decreased. Unless you specifically need low pings for gaming, etc. then it's probably better to leave it on.
Message 22 of 24
(517 Views)
04-07-2011 7:37 PM
Gaming is the main reason I asked for interleaving to be turned off,
Looks like another PN patron had the same thing happen, my noise margin hasn't changed though, it is still around 6 up and 6 down.
Quote Before i had my interleaving turned off i was syncing around 22000 with a profile of 19000 but ever since having interleaving turned of the dlm has changed my snr target everyday and is now at 22 giving me a sync of around 9000
Message 23 of 24
(517 Views)
01-08-2011 7:37 AM
My download speed had dipped to around 15.8mb/s for the last two weeks, but for the past couple of days has risen again, to 16.7mb/s
http://www.speedtest.net/
Message 24 of 24
(517 Views)
- « Previous
- 1
- 2
- Next »
