Is Plusnet Down Again?
- Re: Is Plusnet Down Again?
11-10-2014 5:00 PM
11-10-2014 5:00 PM
Quote from: kitz Looks like a load of gateways shed their load
Due to the all the graphing glitches, the broadband usage graphs won't show anything clearly until a couple of hours after the event.
11-10-2014 5:01 PM
11-10-2014 5:04 PM
11-10-2014 5:04 PM
Quote from: ejs
It can be seen already (see attached).
11-10-2014 5:06 PM
Quote from: woodm Still no luck here. Rebooted router.
If you are using one of the routers from us, please try logging in and manually connecting. Hopefully this should do the trick (http://www.plus.net/home-broadband/router-reconnect/) .
Tony
11-10-2014 5:07 PM
Quote from: misshighlander It was the same for me. Lost internet connection. Turned router off/on again. Service back to normal for me
That's not the best option especially if you are on a longer or awkward line (20CN in particular) and more so after dusk, that's a last resort after trying http://www.plus.net/reboot. You should give if upto 30 minutes as well, before trying a powerdown.
I'm guessing it could have been a major power outage affecting a datacentre or similar especially as the Usage graphs went down (now back up).
Edit: spelling
11-10-2014 5:10 PM
11-10-2014 5:10 PM
@Anotherone - did you miss the previous threads about the large scale BNG gateway outages?
11-10-2014 5:12 PM
Is this the future we, will be looking forward to ?
11-10-2014 5:13 PM
11-10-2014 5:14 PM
Some people need to go to specsavers, from what I can see on the current graphs it's not all or only bng's by any means.
11-10-2014 5:16 PM
Quote from: ejs I guess it was one or more of the BNGs again!
I was bumped off a bng and back on to a ptn about 45 minutes ago.
It's a good thing these drops don't occur at the weekend when there's no support around...
11-10-2014 5:19 PM
Further details will be appearing in the service status posts on the portal - http://portal.plus.net/supportpages.html?a=2&support_action=messages&ispservice_id=adsldial as and when we have updates.
Tony.
11-10-2014 5:19 PM
