Intriguing ADSL2+ behaviour
lahbrannan1
Fixes: 4
Re: Intriguing ADSL2+ behaviour
Thank you for your recent message.
I can run an enhanced diagnostics test to see if there are any underlying issues with your service, please provide us with your account username via private message so we can arrange this.
Lee Plusnet Sheffield
Lee Brannan
198kHz
Fixes: 42
Just to clarify where this 88.2% came from.
On 21CN ADSL, the IP Profile is fixed at 88.2% of the sync speed.
BT technician (Retired)
Mardler
Thanks, Lee.
How do I send you a PM? I tapped on your profile and got the About page but there's no hyperlink on the Contact me "button".
Fixes: 378
@Mardler Try the 'send private message' button (in grey).
Mardler
198khz, it's also described as:-
IP Profile Rate
edit
It is the maximum download rate using the current sync rate. This is also known as the bRAS profile. It is found initially by taking 88.2% of the sync rate. This fraction applies to all 21st Century Network (21CN) ADSL products."
here:-
https://en.m.wikibooks.org/wiki/Internet_ADSL2%2B_Speed
Mardler
jab1, I don't have that option.
Fixes: 378
Strange - I do.
Mardler
jab1, I got that with nothing under the Contact Me box. Tried a 3rd time and it worked.
Fixes: 378
Glad you sorted it, but I have no explanation for why it didn't display correctly.
Mardler
Another update.
I have been otherwise engaged of late and have had no reason to check the connection as all seemed well.
I just took a look and had a bit of a surprise.
My last update outlined the upload speed anomaly (3.3 max) and the high down attenuation (c.19).
Today I find that the connection was reset a week ago at about 08:20 with these current values:-
Down (Up):-
SNR: 6.1 (8.2)
Attenuation: 15.5 (9.9)
Output power: 19 (11.9)
Attainable: 22680 (1283)
Sync: 21539 (1287)
As you can see, this is back to (close to) normal.
I have done nothing thus am lead to think that a fault at the exchange has been corrected.
Any thoughts?
