Internet connection on an iMac
clast49
I’ve just had full fibre installed. My iPad, too, iPhone connect to the internet OK but I have a problem with my iMac. When I connect to the router it says I’m connected to broadband but I cannot connect to internet sites. Help
14 REPLIES 14
Fixes: 246
Re: Internet connection on an iMac
Connected to the router how?
Do you have any Ethernet over power adapters in use?
clast49
All the connections are through Wi-Fi
Fixes: 246
Ethernet over power adapters?
clast49
I’m afraid I don’t understand
Fixes: 246
Do you have any devices which extend your network over the mains power circuit?
clast49
No I don't
RPMozley
Seasoned Pro
Fixes: 16
What does it say in System Preferences->Network->WiFi ?
That's RPM to you!!
clast49
It shows I'm connected to my router
RPMozley
Seasoned Pro
Fixes: 16
What system version is the iMac 🖥 running on?
That's RPM to you!!
clast49
Sequoia 15.4
RPMozley
Seasoned Pro
Fixes: 16
Ah, right. System Preferences looks more like iOS in the newer macOS versions.
Try some “fixes” from this webpage;
https://osxdaily.com/2024/10/08/fix-macos-sequoia-network-wifi-issues/
I’ve no idea if any of these work as my Mac is stuck on Catalina.
That's RPM to you!!
clast49
I think it’s sorted now. Thanks for your help
Fixes: 1,495
@clast49 - can you tell us what you did as it might help others in future Smiley
clast49
The problem seemed to be more speed and another post relating to 2.4GHz and 5GHz seems to explain the issue.
