Internet not working
Taylor77
My iphone/laptop says I’m connected to the wifi but there is no internet connection no link appears to try and fix as upon re searching it says people are being asked to authenticate we havent seen this - our router isnt the problem we have re set and us still blue and working please help
15 REPLIES 15
Fixes: 387
Re: Internet not working
@Taylor77 I'm confused - if you are not connected to the internet, how have you posted this? A little more detail would help? Which Hub have you got?
Taylor77
Hi i’m using 4g on my phone every device we have says we have wifi but underneath it says no internet connection - Hub one is what we have
Fixes: 387
OK, sorry, should have realised you could use 4G. What does this page from your Hub show? Which OS are you using -W10, W11 or some other?
Taylor77
This page wont appear for us it did last night but it now no longer will pop up on any of our devices so we are unsure
Fixes: 387
Do you have a land-line phone connected ?
Taylor77
No we dont have a landline
Fixes: 387
OK. I'll tag someone who may be more awake than me as I'm a bit stumped.
@Baldrick1  - any thoughts?
Fixes: 479
@Taylor77
Which hub have you got and what lights are showing.
Taylor77
Hub1 and orange
Fixes: 479
@Taylor77
Report a fault, see https://www.plus.net/help/report-a-problem/broadband/#broadband
DerekW
I am assuming you have done the old "disconnect the power from the hub for 5 minuets" trick?
"No one has ever become poor by giving" - Anne Frank
Fixes: 387
@DerekW If the Hub light is orange, there is a network fault, hence @Baldrick1 's advice.
DerekW
I have had the orange light showing on the hub a couple of time in the past and disconnecting the power from the hub for 5 min helped to get things working again, hence my post 😉
It certainly won't hurt to try
The Hub One has two lights which relate to the connection condition
The power light and the b light (broadband)
Once the Hub has been through it's self tests the power light will be a solid Orange which will turn Blue once a successful broadband user has logged on.
If the light stays solid orange the 'broadband' status is important
Broadband light is red - You've tried to log in with the wrong username and password. Reset your Hub's password to its factory setting (shown on the card that came with your Hub) by using a paper clip to press the recessed Reset button on the back of your Hub for a few seconds
Broadband light is flashing red - There's a problem with your broadband line. Check that all the cables are plugged in correctly.
HTH
