Internet connection on an iMac
- Re: Internet connection on an iMac
03-04-2025 8:07 PM
I’ve just had full fibre installed. My iPad, too, iPhone connect to the internet OK but I have a problem with my iMac. When I connect to the router it says I’m connected to broadband but I cannot connect to internet sites. Help
04-04-2025 1:56 PM
Connected to the router how?
Do you have any Ethernet over power adapters in use?
04-04-2025 5:16 PM
All the connections are through Wi-Fi
04-04-2025 9:23 PM
05-04-2025 8:11 AM
I’m afraid I don’t understand
05-04-2025 12:18 PM
Do you have any devices which extend your network over the mains power circuit?
05-04-2025 11:01 PM
No I don't
07-04-2025 5:25 PM
07-04-2025 5:34 PM
It shows I'm connected to my router
07-04-2025 5:38 PM
07-04-2025 5:51 PM
Sequoia 15.4
07-04-2025 6:04 PM
Try some “fixes” from this webpage;
https://osxdaily.com/2024/10/08/fix-macos-sequoia-network-wifi-issues/
I’ve no idea if any of these work as my Mac is stuck on Catalina.
10-04-2025 7:08 AM
I think it’s sorted now. Thanks for your help
10-04-2025 8:50 AM
10-04-2025 5:13 PM
The problem seemed to be more speed and another post relating to 2.4GHz and 5GHz seems to explain the issue.
