Internet connection keeps dropping
massiF
Hello,
since yesterday morning my internet connection keeps randomly dropping, every half an hour or so, for a couple of minutes. To be clear, it’s not the Wi-Fi signal, my laptop is connected with a cable, it’s the broadband connection. The orange light flashes for a couple of minutes and it becomes blue again.
Any fault on the line? I used to have a similar problem a few months ago, magically fixed after a couple of day, no idea if there was a fault on the line.
Thank
3 REPLIES 3
adam945
Fixes: 113
Re: Internet connection keeps dropping
Hi there, thanks for reaching out and I'm sorry to hear this.
I've responded to you here if you'd like to have a look - https://community.plus.net/t5/ADSL-Broadband/Re-Connection-dropping-unable-report-the-fault/m-p/1827...
 Adam
 Plusnet Help Team - Leeds
massiF
Connection has been stable the whole afternoon 🤞 I’ll keep an eye on it and in case report the fault, thanks for your help.
LaurenB
Fixes: 131
That's good to hear @massiF, should you have any further issues just follow the steps my colleague provided.
Hope you have a good day.
 Lauren Barry
