Internet says connected but not working
- Internet says connected but not working
08-09-2021 10:13 PM
Hi, plusnet was “down” locally on Tuesday & I have had to use a hotspot for work since then. The light is now blue & it says I am connected, it then takes me to a “captive portal authorisation” page which also says I am connected to the internet, but I am not. I have restarted several times & my laptop & phone also. Still no Internet, can someone please tell me what is wrong & how to fix this so I can do my job, thanks.
Message 1 of 4
(2,518 Views)
3 REPLIES 3
Re: Internet says connected but not working
08-09-2021 10:39 PM
Log into the router, go to the advanced broadband settings, and if the username is setup@plusdsl.net diconnect and change to your correct username and password.
It may work if you try something in the pinhole at the rear for 30 secs and wait to see if that corrects things.
Message 2 of 4
(2,513 Views)
08-09-2021 11:09 PM
Thank you! It’s working now.
08-09-2021 11:35 PM
Cool, glad you are sorted.
Feel free to click on the Thumbs up/Thanks tab, even better the one that says my answer fixed your problem.
Message 4 of 4
(2,492 Views)
