Interleaving switch to off please
- Re: Interleaving switch to off please
20-03-2014 7:40 PM
As per the title my ping is running about 32ms on interleave path (I'm told it says auto) so can I have it changed to fast path so I can see if it drops it some more as titanfall is feeling a little laggy at times
Message 1 of 8
(1,227 Views)
7 REPLIES 7
21-03-2014 12:33 PM
Message 2 of 8
(678 Views)
21-03-2014 12:35 PM
Thanks Adam
Message 3 of 8
(678 Views)
24-03-2014 8:38 PM
Still showing as interleaved path
Message 4 of 8
(678 Views)
25-03-2014 11:23 AM
Your Interleaving is definitely off:
WBC 160K - 24M No delay (INP 0) 6dB Downstream, UC No delay (INP 0) 6dB Upstream
0 = Interleaving Off
1/2/4/8 = Different levels of Interleaving
When Interleaving is on Auto is means DLM can put Interleaving back on straight away. I'll place an order for it to be 'Off'. This order should complete tomorrow, early morning for you.
Message 5 of 8
(678 Views)
25-03-2014 11:26 AM
Message 6 of 8
(678 Views)
25-03-2014 11:38 AM
If your line becomes stable at any time, our suppliers can put Interleaving back on, this can be done whether we turn it off or not unfortunately.
It may be that Interleaving was set to Auto due to a brief period of instability at some point. I'll get it turned off for tomorrow morning and see if that makes any difference for you.
Message 7 of 8
(678 Views)
25-03-2014 11:40 AM
Ok thanks, Its more just to see if this helps the lag in titanfall but from what I read I'm better off with a poorer connection and high ping rate so I don't know that this will help
Message 8 of 8
(678 Views)
