Interleaved / fastpath ?????
- Re: Interleaved / fastpath ?????
05-08-2012 9:30 PM
i have just changed routers this evening , my previous router showed Fastpath (well it did last time i looked ! and i had good speed and stability with good ping times (i am on the pro add on package ) after installing my new router i checked settings and it shows it as being interleaved (on), is it possible that it could have changed because of router .
as i,m on the pro add on package i would have thought it should have been fastpath ... although i,m not sure what the difference is .
on a different note could a member of the plusnet team please uncap my upload ?
06-08-2012 12:26 PM
I can see that you have had disconnections and errors on your line, this will appear to be why interleaving has been turned on.
If you have turned your router off a few times while changing routers over, that may have caused interleaving to be turned on. We need to monitor you connection and see if your line is stable before we look at turning interleaving off.
I have uncapped the upload speed on your line, this will take one working day to complete.
Let me know how your connection is and then we'll look at turning interleaving off.
06-08-2012 1:23 PM
thanks for the upload uncap , when are the disconections showing , when i changed routers the old one showed fastpath , after i,d finsihed changing routers , up grading firmware etc the new router showed interleaved ... i checked because i noticed that lag had reappeared in gaming .before changing routers i had not had any disconnections etc apart from them mention in my other post
cheers
wayne
06-08-2012 1:52 PM
Your disconnections are showing from last night between 8.00 - 10.15PM. If your line does remain stable over the next 48 hours then we can certainly look at turning interleaving off.
Chris
06-08-2012 2:02 PM
yeh thats the time scale in which i changed my router . had the new one sat there for a week or so but was letting my line settle down etc ... so decided to change it last night .
i,m sure it will be fine .
thanks for looking into this , i have raised a ticket (#58434752) as per instructions on one of PN gaming tips pages
thanks again
07-08-2012 11:10 AM
Enjoy your gaming
If there's anything else then let me know.
07-08-2012 3:00 PM
uplaod speed increased already , still showing interleaved , but i understand it takes up to 72 hrs to come into force .
thanks for your help with this
waynem
07-08-2012 4:58 PM
Interleaving varies in the time it takes to turn on/off, it is still showing as on. It will turn off at some point soon.
Let me know if it hasn't and I;ll chase that up for you.
chris
07-08-2012 7:30 PM
Hold up .... now seems to be back to normal ? how bizarre !!!
wayne
08-08-2012 1:18 PM
Any changes let me know.
Chris
08-08-2012 3:02 PM
still showing as interleaved on in the router at the moment , but my connection is fine so it will go to fastpath when ever ..... .
i do have a question re turning router router on and off etc ... i,m now using Belkin surf N150 ..which seems great but again as with my other belkin no disconnect ...but it does have self healing ?? which is a system to set your router to restart daily, weekly etc .. have it turned off at the minute as it has been mentioned that the exchange see,s disconnections as a potential problem . reading on the forum the general advice seems to be leave router on .... your thoughts ?
wayne m
cheers again for your help
08-08-2012 4:36 PM
As long as your line was running fine and no disconnections, a weekly self healing wouldn't have a impact on your connection.
08-08-2012 7:13 PM
10-08-2012 9:35 AM
i have a few questions ...sorry .
i receieved this Service Notice #139337272 a couple of days ago and since then there have been alot of variation in speeds and also max speed has dropped by about 1/2 mb also i noticed that the downstream figure has dropped from 7836 ish
Type Interleave Path
Status SHOWTIME
Downstream Upstream
Data rate(Kbps) 6936 1103
Noise Margin 6 5
Output power(dBm) 12 20
Attenuation(dB) 43 25
as you can see its still showing as interleaved ..
before the service notice i had a good solid non fluctuating 6.5 (speedtest) all through the day now it seems dependant on time of day etc ...Traffic management ? .
sorry to be a pain and appreciate your help
waynem
10-08-2012 12:24 PM
Looks like fastpath should be on, that's what it's showing on the checks on our suppliers' site. It's also showing a profile of 6900 which matches on our side, that looks to be about the fastest it's been since the middle of last month?
Let us know if that's not what you're seeing and we can do some more checking for you.
