Increase upload speed
JohnPhil
Re: Increase upload speed
Do they need to install new copper between the street cab and the living room socket?
Fixes: 374
No, they need to install a Fibre cabinet next to your current street cab - which they won't - and then connect the fibre cab to the copper one. FTTC means  Fibre To The Cabinet, the 'last mile', or more precisely the connection from said cab to your property is then the only copper, and does not change.
JohnPhil
Why aren't they going to install a new fibre cab next to the existing one?
Fixes: 374
Probably because it is an expensive undertaking, and if Full Fibre is to be installed in the near future, not a cost-effective venture.
pvmb
All Star
Fixes: 13
@JohnPhil wrote:
That's not ADSL.
Yes it is! The OP said so.
pvmb
All Star
Fixes: 13
...I see what you mean. 🤣
JohnPhil
I see, thanks for the exchange (no pun intended), hope they'll meet their deadline next year.
