Identifying peer to peer activity
- Re: Identifying peer to peer activity
25-11-2008 12:31 AM
For the first time, my internet activities is showing peer to peer. Is there any way of identifying what that is? I want to ensure that none of the kids are doing file sharing, but it could be Iplayer, or possibly a game download (eg wow)
Is there any way I can just disable peer to peer at plusnet end? There are 5 pc's in use here, so doing it at this end would be time consuming.
25-11-2008 12:35 AM
You can stop peer to peer at a stroke
Go to https://portal.plus.net/surf/, sign in and activate surf, reboot your router or sign off and sign back on in the router's control panel and P2P will be blocked.
I should point out that only the standard ports are blocked.
HTH
25-11-2008 8:17 PM
I would still like to find out what the P2P activity was though if that is possible.
25-11-2008 8:23 PM
As for as your P2P activity, you don't run 4 on Demand or Demand 5 do you as these install a sneaky little peer to peer server process called KService which helps C4/five reduce its bandwidth bill by using yours to serve programs you download to others.
25-11-2008 8:43 PM
25-11-2008 8:46 PM
25-11-2008 8:48 PM
25-11-2008 10:45 PM
25-11-2008 11:36 PM
Forum Moderator and Customer
25-11-2008 11:53 PM
cp:quote
25-11-2008 11:59 PM
26-11-2008 9:32 AM
Is any upstream serving of downloaded programmes classified as p2p?
26-11-2008 9:40 AM
Quote from: techguy Is any upstream serving of downloaded programmes classified as p2p?
Hi, Up/Down all Streaming
26-11-2008 9:41 AM
Quote from: Mav Thanks for the clarification _CN_, but why are the downloads not classed as p2p?
Hopefully the comms guys can give you that answer, I'm not sure to be honest
