IP profile
Bensonp
IP profile
This is my router info as requested by mod Smiley
Modem Status Connected
DownStream Connection Speed 3971 Kbps
UpStream Connection Speed 448 Kbps
VPI 0
VCI 38
and this was my speed results :-
1. Best Effort Test:  -provides background information.
Download  Speed
3.34 Mbps
0 Mbps 4 Mbps
Max Achievable Speed
Download speedachieved during the test was - 3.34 Mbps
For your connection, the acceptable range of speeds is 1.2 Mbps-4 Mbps.
IP Profile for your line is - 3.5 Mbps
2. Upstream Test:  -provides background information.
Upload Speed
0.35 Mbps
0 Mbps 0.45 Mbps
Upload speed achieved during the test was - 0.35Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.45 Mbps
Can this be upped any more, every little helps Smiley
Paul
16 REPLIES 16
Fixes: 162
Re: IP profile
Can this be improved?
That would depend on other router metrics which you have not disclosed.  Knowledge of the US and DS attenuation and SNRM will allow an assessment of the viability of squeezing more synch speed out of the line.
Your data transfer rate looks good for the synch speed.
Bensonp
Re: IP profile
ADSL Link Downstream Upstream
Link Rate 3971 Kbps 448 Kbps
Line Attenuation 56.0 dB 34.1 dB
Noise Margin 3.2 dB 10.7 dB
Is this the info
Anotherone
Champion
Fixes: 21
Re: IP profile
Hi again Paul,
getting closer  Wink
When you log in to the Modem/Router you find yourself at the Home page. Select Broadband Connection on the LHS.Then select DSL Connection below that or alternatively View more...... in the middle. Then on the RHS click Details and you should then see something like -
Link Information
Uptime: 0 days, 1:18:25
DSL Type: ITU-T G.992.1
Bandwidth (Up/Down) [kbps/kbps]: 448 / 7,456
Data Transferred (Sent/Received) [MB/MB]: 2.18 / 1.74
Output Power (Up/Down) [dBm]: 12.5 / 19.8
Line Attenuation (Up/Down) [dB]: 21.5 / 39.0
SN Margin (Up/Down) [dB]: 9.0 / 6.2
Chipset Vendor ID (Local/Remote): BDCM / TSTC
Loss of Framing (Local/Remote): 0 / -
Loss of Signal (Local/Remote): 0 / -
Loss of Power (Local/Remote): 0 / -
Loss of Link (Remote): -
Error Seconds (Local/Remote): 2 / -
FEC Errors (Up/Down): 9 / 1,676
CRC Errors (Up/Down): 0 / 2
HEC Errors (Up/Down): - / 12
Just do a copy and paste of yours and post it.
HTH.
Bensonp
Re: IP profile
Nah you got me lol, looked everywhere for this info and cannot find it the router is a Netgear DGN2200v3. I have clicked on all the setting tabs and cannot find any thing that looks similar to what you have posted :9
Anotherone
Champion
Fixes: 21
Re: IP profile
Ah, now there was me thinking you had a tg582n, that explains it, sorry you won't get that lot. What you've posted will have to do, it would have been nice to see some error figures, I'm not sure where they are on that one, if they are shown, if you know post them.
Anotherone
Champion
Fixes: 21
Re: IP profile
Just had a quick look at the manual, if you are running standard firmware, it doesn't give them. So ..
As far as the stats above go your line is doing a touch better than some would. But tell use a bit about you installation and we'll see if there's anything that might improve it.
Do you have a Master Socket like the one on the left?
It has the join across it half way down.
Do you have any extension phone sockets, and where are you currently plugged in? Are you using any plug-in phone/router extension leads?
I presume you can't hear/have heard any crackling or other noises on the line when using the phone nor have you had any problems with incoming or outgoing calls?
Bensonp
Re: IP profile
Open reach fitted a new style fibre socket when they found the issue with the line which was external to the house (noise on the line) they have now wired so no external filters are needed at any ext point.
No noise on line
Paul
Anotherone
Champion
Fixes: 21
Re: IP profile
Ah ok that's good, so you are plugged into the top socket on that then? And do you have any fixed extensions at all?
Bensonp
Re: IP profile
Yes router plugged into top socket only ext is a phone downstairs and the alarm panel Smiley these no longer have micro filters attached
Kind regards
Paul
Anotherone
Champion
Fixes: 21
Re: IP profile
Ok then I don't think there's an awful lot more to suggest.  I would have suggested looking at bell wires, but if you have an alarm system, I'm reluctant to suggest you tamper. See how it goes, with your external problem sorted let's hope your connection is stable.
njay
Re: IP profile
I believe the vdsl2 interstertial plate filters the bell wire so that it doesn't back feed onto the unfiltered data socket.
Bensonp
Re: IP profile
I have already removed pin 3 (bell wire) from all the sockets
Anotherone
Champion
Fixes: 21
Re: IP profile
Ah, good. OK Smiley Did you remove it at the master? Which you can do at some convenient point if you didn't.
@njay
That is actually irrelevant, the filtering isn't always 100% effective. It's a similar situation with the older BT SSFP and some other Filtered Front plates and often removal of the bell wire will give further improvement.
Bensonp
Re: IP profile
so it looks like im getting the best possible ip profile?
