IP profile
- Re: IP profile
IP profile
22-05-2013 4:38 PM
Modem Status Connected
DownStream Connection Speed 3971 Kbps
UpStream Connection Speed 448 Kbps
VPI 0
VCI 38
and this was my speed results :-
1. Best Effort Test: -provides background information.
Download Speed
3.34 Mbps
0 Mbps 4 Mbps
Max Achievable Speed
Download speedachieved during the test was - 3.34 Mbps
For your connection, the acceptable range of speeds is 1.2 Mbps-4 Mbps.
IP Profile for your line is - 3.5 Mbps
Upload Speed
0.35 Mbps
0 Mbps 0.45 Mbps
Upload speed achieved during the test was - 0.35Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.45 Mbps
Can this be upped any more, every little helps
Paul
Re: IP profile
22-05-2013 5:04 PM
That would depend on other router metrics which you have not disclosed. Knowledge of the US and DS attenuation and SNRM will allow an assessment of the viability of squeezing more synch speed out of the line.
Your data transfer rate looks good for the synch speed.
Re: IP profile
22-05-2013 6:44 PM
ADSL Link Downstream Upstream
Link Rate 3971 Kbps 448 Kbps
Line Attenuation 56.0 dB 34.1 dB
Noise Margin 3.2 dB 10.7 dB
Is this the info
Re: IP profile
22-05-2013 6:51 PM
getting closer
When you log in to the Modem/Router you find yourself at the Home page. Select Broadband Connection on the LHS.Then select DSL Connection below that or alternatively View more...... in the middle. Then on the RHS click Details and you should then see something like -
Link Information
Uptime: 0 days, 1:18:25
DSL Type: ITU-T G.992.1
Bandwidth (Up/Down) [kbps/kbps]: 448 / 7,456
Data Transferred (Sent/Received) [MB/MB]: 2.18 / 1.74
Output Power (Up/Down) [dBm]: 12.5 / 19.8
Line Attenuation (Up/Down) [dB]: 21.5 / 39.0
SN Margin (Up/Down) [dB]: 9.0 / 6.2
Chipset Vendor ID (Local/Remote): BDCM / TSTC
Loss of Framing (Local/Remote): 0 / -
Loss of Signal (Local/Remote): 0 / -
Loss of Power (Local/Remote): 0 / -
Loss of Link (Remote): -
Error Seconds (Local/Remote): 2 / -
FEC Errors (Up/Down): 9 / 1,676
CRC Errors (Up/Down): 0 / 2
HEC Errors (Up/Down): - / 12
Just do a copy and paste of yours and post it.
HTH.
Re: IP profile
22-05-2013 7:04 PM
Re: IP profile
22-05-2013 7:11 PM
Re: IP profile
22-05-2013 7:19 PM
As far as the stats above go your line is doing a touch better than some would. But tell use a bit about you installation and we'll see if there's anything that might improve it.
Do you have a Master Socket like the one on the left?
It has the join across it half way down.
Do you have any extension phone sockets, and where are you currently plugged in? Are you using any plug-in phone/router extension leads?
I presume you can't hear/have heard any crackling or other noises on the line when using the phone nor have you had any problems with incoming or outgoing calls?
Re: IP profile
22-05-2013 7:30 PM
No noise on line
Paul
Re: IP profile
22-05-2013 7:34 PM
Re: IP profile
22-05-2013 7:39 PM
Kind regards
Paul
Re: IP profile
22-05-2013 7:56 PM
Re: IP profile
22-05-2013 7:59 PM
Re: IP profile
22-05-2013 8:01 PM
Re: IP profile
22-05-2013 8:05 PM
@njay
That is actually irrelevant, the filtering isn't always 100% effective. It's a similar situation with the older BT SSFP and some other Filtered Front plates and often removal of the bell wire will give further improvement.
Re: IP profile
23-05-2013 11:52 AM
