Huge packet loss on specific destinations
- Re: Huge packet loss on specific destinations
26-11-2013 3:41 PM
I have a huge packet loss (40%+) on specific destinations during afternoon times. Problem arises from 1-3pm every day and disappears at 8-9pm. Packet loss happens on routes through RETN LINX server, I've tested many other routes and no problems there, only with RETN route. I've opened CS ticket with the same question, but still got no answer. I'm attaching graphs from monitoring software so you can see where and when problem occurs. Would be nice to get some reply from tech stuff with suggestions how to fix/avoid this problem.
26-11-2013 4:37 PM
I've taken a look over your connection and can't see anything from our end and from our suppliers systems that would indicate a problem.
You mention that the issue only happens on RETN route, is that right? You don't have any other issues with different routes?
26-11-2013 4:53 PM
Yes, as I mentioned, problems only occur on RETN route (packet loss starts between ae2.ptw-cr01.plus.net and linx-224.retn.net routers as you can see on the graphs attached), for example, try to trace ya.ru server from your workplace. I believe it isn't problem with PlusNET itself or with "last mile" suppliers, the problem is with connection to the RETN LINX router. I'm not sure what could be done, maybe need to change routing tables to avoid RETN LINX server, or need to contact RETN itself and see what can they say.
jim:quote
26-11-2013 5:29 PM
Ex-Broadband Service Manager
26-11-2013 5:36 PM
HopIP Hostname last [ms]min [ms]max [ms]ava. [ms]var. [ms]total Lossperc. RTTL ASN
1 10.3.5.253 10.3.5.253 0 0 0 0 0 255 AS65534
2 10.0.3.5 10.0.3.5 0 0 0 0 0 0 0 64 AS1
3 84.93.216.88 vlan380.pbs-cr01.plus.net 1 1 1 0 1 0 0 254 AS6871
4 84.93.216.95 gi6-8.ptp-cr01.plus.net 1 1 5 1 1 0 0 253 AS6871
5 84.93.224.49 gi1-22.pcl-gw01.plus.net 8 8 21 10 4 0 0 252 AS6871
6 195.166.129.40 ae3.pcl-cr01.plus.net 8 8 44 10 8 0 0 60 AS6871
7 195.166.129.0 ae1.ptw-cr01.plus.net 8 8 42 11 9 0 0 60 AS6871
8 195.66.224.193 linx-224.retn.net 106 102 163 109 14 0 0 AS10026
9 87.245.233.237 ae6-10.RT.EQX.FKT.DE.retn.net 124 119 133 124 3 0 0 58 AS9002
10 87.245.246.150 GW-IntecTradeInc.retn.net 124 117 125 122 2 0 0 57 AS9002
11 176.122.240.130unused-176.122.240.130.intectradeinc.com 125 117 125 121 2 0 0 56 AS59513
12 176.122.240.253176.122.240.253 122 119 123 121 1 0 0 56
26-11-2013 5:36 PM
C:\Users\Oruvin>tracert ya.ru
Tracing route to ya.ru [87.250.250.203]
over a maximum of 30 hops:
1 1 ms <1 ms <1 ms RT-N66U [192.168.10.1]
2 15 ms 15 ms 15 ms lo0-central10.ptw-ag01.plus.net [195.166.128.195]
3 15 ms 15 ms 15 ms link-b-central10.ptw-gw02.plus.net [212.159.2.146]
4 15 ms 15 ms 17 ms xe-4-2-0.ptw-cr02.plus.net [212.159.0.242]
5 15 ms 16 ms 15 ms ae2.ptw-cr01.plus.net [195.166.129.4]
6 * * 87 ms linx-224.retn.net [195.66.224.193]
7 * 94 ms * ae2-9.RT.TC2.AMS.NL.retn.net [87.245.233.97]
8 93 ms 93 ms * GW-Yandex.retn.net [87.245.246.14]
9 96 ms * 94 ms tulip-ae1-0.yndx.net [87.250.239.46]
10 * 96 ms * www.yandex.ru [87.250.250.203]
11 * * 91 ms www.yandex.ru [87.250.250.203]
Trace complete.
26-11-2013 5:40 PM
As I see you have no packet loss, BUT you have different PlusNET router (ae1.ptw-cr01.plus.net) connected to the RETN network, my route is going through ae2.ptw-cr01.plus.net router. Maybe there is problem with PlusNET router (ae2.ptw-cr01.plus.net)?
26-11-2013 5:43 PM
www.yandex.ru
HopIP Hostname last [ms]min [ms]max [ms]ava. [ms]var. [ms]total Lossperc. LossLatitudeLongitudeRTTLASN
2 10.0.3.5 10.0.3.5 0 0 1 0 0 0 64 AS59513
3 84.93.216.88 vlan380.pbs-cr01.plus.net 0 0 6 1 1 0 254 AS6871
4 84.93.216.95 gi6-8.ptp-cr01.plus.net 3 1 14 2 3 0 253 AS6871
5 84.93.224.49 gi1-22.pcl-gw01.plus.net 8 8 8 8 0 0 252 AS6871
6 195.166.129.40 ae3.pcl-cr01.plus.net 8 8 22 9 3 0 60 AS6871
7 195.166.129.0 ae1.ptw-cr01.plus.net 8 8 9 8 0 0 60 AS6871
8 195.66.224.193 linx-224.retn.net 105 101 136 107 7 0 AS10026
9 87.245.233.97 ae2-9.RT.TC2.AMS.NL.retn.net 113 108 118 111 2 1 0 58 AS9002
10 87.245.246.14 GW-Yandex.retn.net 110 109 112 111 1 0 57 AS9002
11 87.250.239.46 tulip-ae1-0.yndx.net 114 110 114 112 1 0 53 AS13238
12 87.250.250.3 www.yandex.ru ; 113 109 115 112 1 1 0 52 AS13238
13 87.250.250.3 www.yandex.ru ; 111 111 111 111 0
26-11-2013 5:50 PM
02-01-2014 3:47 PM
02-01-2014 4:48 PM
02-01-2014 4:52 PM
What do traces to other URLs look like?
02-01-2014 4:53 PM
<img src="http://community.plus.net/visualradius/generated/image13886815344503.png"/>
02-01-2014 4:57 PM
Yes, I've been trying to get a different IP to see if I get different route (routes were different, but all of them had same issues with linx-224.retn.net router), that's why you see many reconnects.
As I mentioned in early posts, problem ONLY occurs within RETN network (RETN LINX), with all other routes (that I'm using) there is absolutely no problem.
02-01-2014 4:58 PM
