Hub2 connection log
iwbrock
Hub2 connection log
Hi All,
I'm having some issues with random broadband dropout and am trying to get my router connection log, but it only seems to be showing the last 15 or so hours, should I be able to see more than this?This coresponds to the last drop out, so wondering if the log resets when the hub does?
17 REPLIES 17
Fixes: 382
Re: Hub2 connection log
@iwbrock What do you get if you click the 'export' tab on that page - it should produce a .csv file?
Fixes: 147
@iwbrock
The log should go back to when the Hub was first switched on or the last time a factory default was performed. Some event log categories history is limited. FWRL being an example
The WAN log on my Hub two has entries from 21 Sept 2024 which is when I last performed a reset
HTH
iwbrock
Hi John
I will have a look this evening and get back to you on that one.
iwbrock
Exporting the event log worked. I am getting SIP WAN DOWN SIP WAN UP logged  at the time of each disconnection.
EVENT SEEMS TO GO AS FOLLOWS:
(attached)
Fixes: 382
@iwbrock Is that what you always get? Out of interest are you on FTTC or FTTP?
Fixes: 147
@iwbrock
The plusnet Hub two is based on the BT Smart Hub 2, they have many things income but, the plusnet Hub two does not support digital phone, the SIP WAN DOWN SIP WAN UP are associate with that function.
So they can be ignored, nothing to do with FTTC or FTTP connections
Fixes: 382
Thanks, @Dan_the_Van  - I was just researching that as I didn't know what it was all about. I reckon we need the full log?
Fixes: 147
@jab1
The SIP messages only appear on a line restart so yes full log is required, but saying that the event log extract was overnight so may be maintenance
iwbrock
Ok, full log attached.
I don't know if this is the usual pattern, this is the first time I've looked at the logs on this router.
The 19th of this month was particularly bad for disconnects. There were around 6 I think that led to a resync.
I am on FTTC
Fixes: 382
@Dan_the_Van I agree, the 'snippet' could be maintenance - in fact probably is - but I can't see any connection issues in the full log, only devices losing and then - eventually - regaining connection.
Beyond my knowledge, so if you want this one, feel free. 😀
Fixes: 147
@iwbrock
I see you have another thread running
https://community.plus.net/t5/Everything-else/Any-way-to-see-if-an-engineer-booking-has-happened/td-...
Have you had an engineer visit yet, as you line does not look very stable to me, (I'm sure @jab1 will agree)
There looks to be a line fault as the sync rate is variable
08:41:33, 26 Mar. DSL Link Up: Down Rate=79999kbps, Up Rate=20000kbps; SNR Margin Down=7.5dB, Up=13.8dB
06:25:57, 26 Mar. DSL Link Up: Down Rate=38695kbps, Up Rate=19999kbps; SNR Margin Down=6.2dB, Up=6.2dB
EDIT: do a search for DSL Link Down in the full log
iwbrock
I had one booked and  the case got closed, but no one came to the house and I can see the cabinet and no-one was in it in the allocated window for the visit, so who knows if I actually got an engineer visit, or if they tested the line and there was no active fault at that time.
Fixes: 382
I do agree, @Dan_the_Van . Mind you, with all the guff on that log, I hadn't got round to checking the DSL - I'll go and have a look.
EDIT - yep there is definitely a line fault somewhere.
Fixes: 147
@iwbrock
I think you need to speak to plusnet support and say you are not convinced the issue is resolved as the line is not providing a stable connection.
