Hub reboots
- Re: Hub reboots
Hub reboots
09-12-2022 7:29 AM
Re: Hub reboots
09-12-2022 7:35 AM
@grizedale Can you supply the WAN tab from you're 'Events Log' please?
Re: Hub reboots
09-12-2022 7:38 AM
I'm sure I can, would you mind giving a helping hand as to where it is please...
Re: Hub reboots
09-12-2022 7:40 AM
Which Hub do you have - Hub1 or Hub2? May be a little while before I get back to you as I have something else needing doing.
Re: Hub reboots
09-12-2022 7:53 AM - edited 09-12-2022 7:56 AM
Smarthub 6
Event log attached {removed as the wrong one}
Re: Hub reboots
09-12-2022 7:55 AM
Found the WAN tab
Attached
Re: Hub reboots
09-12-2022 8:05 AM
Thanks for that. It is a long log 😉, but my initial thought is that the Hub could be failing - how long have you had it? Some of those entries are a little concerning, especially those reporting 0.0 SNR figures.
My networking knowledge doesn't make me 100% confident to make a definite diagnosis, so I'm going to tag @Dan_the_Van who may be better able to comment.
Re: Hub reboots
09-12-2022 8:11 AM
Hub is just over 2 years old...
Re: Hub reboots
09-12-2022 8:17 AM
It is a BT HH6? Age can be irrelevant - electrical devices can fail. I suggest you wait for Dan-the-van to reply before doing much else.
Do you have any other modem/router you could try? If you say 'yes, I have a Plusnet Hub', that may not be a lot of good, as I suspect it will be on an old, non-updatable firmware.
Re: Hub reboots
09-12-2022 8:19 AM
Thanks for what you are doing, i dont have another hub.
Re: Hub reboots
09-12-2022 8:21 AM
Unfortunate. I'm sure @Dan_the_Van will pop up sometime soon.
Re: Hub reboots
09-12-2022 8:29 AM
Reading a bit more of that long log, I'm now wondering if this could be a BT/OR network problem, Assuming your phone line passes test, it may be an idea to report a broadband fault.
It sounds very much like you have a problem - most likely not in your home/office environment, but more likely in the BT/OR network.
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
Re: Hub reboots
09-12-2022 8:31 AM - edited 09-12-2022 8:32 AM
The number of DSL Link up messages are greater than the DSL Link down messages.
The fact the led goes green to me suggests the hub is restarting as you have mentioned.
Can you provide a copy of the event log this time selecting ALL. Be good to see what leads up to the DSL link up message which hasn't followed a DSL link down, hopefully help explain the SNR Margin Down=0.0dB, Up=0.0dB which makes no sense me.
Edit: is there a Help Page tab you can also post?
Re: Hub reboots
09-12-2022 8:34 AM
Cheers, @Dan_the_Van - I shouldn't pick these complex ones up until I've had my second (at least) coffee. 😀
Re: Hub reboots
09-12-2022 8:51 AM
Hi both
I dont have a landline phone so cannot check.
ALL log attached
