Hub has detected a problem with my internet connection
KrazyyOne
Re: Hub has detected a problem with my internet connection
@Baldrick1 We don't have a phone as we only need the internet. I will have to go and buy one. Plusnet are saying perhaps the broadband might start later even though received messages saying it's all good to go.
Fixes: 334
@KrazyyOne Just out of curiosity, you registered her mid-June. Who were you with previously?
KrazyyOne
We've only just moved into this flat so haven't had the internet here before. Previously we were with Now
Fixes: 334
OK.
jontysoper
Hi KrazyyOne,
Just chipping-in here, I'm no expert in these matters.
You mentioned you've not long moved into the property - so haven't had the internet there before.  But there was already a router in place?  Whose?
I moved house a few years ago and there was a selection of sockets available - but only one (in a bedroom) allowed my router to connect.  The others all had a dial tone.  I put it down to the previous owner going FTTC and what seemed to be the previous master socket had been relocated.  If you have other sockets, it'd be worth a try?
Jonty.
KrazyyOne
Not sure who he was with but he had left a cable and filter in the place where we plugged into.
Fixes: 459
@KrazyyOne
A corded phone is a useful fault diagnostic tool, can be used in an emergency and need not be expensive, see https://www.argos.co.uk/product/5529610?clickPR=plp:6:11
As @jontysoper  indicates, if the property has a master socket with a filtered faceplate and extensions are correctly wired, the hub will only work if plugged into the dsl socket on the master socket filter.
Fixes: 530
if its a mk4 filtered faceplate then that doesn't make sense
as @jab1 said earlier, a photo would be very useful
KrazyyOne
Sorry can't see how to upload an image
Fixes: 334
As you are using a phone/tablet on 3G/4G, if you request the desktop version of the site, you will find to the right of the 'smiley' icon a 'mountain' icon - click on that and follow instructions.
KrazyyOne
Fixes: 334
Cheers, @KrazyyOne .
@Baldrick1 / @MisterW - is that an old-style filtered socket?
Fixes: 530
@jab1 no, its just a very old dual socket. I'm not even sure that will be the master socket ?
Without a phone, it will be difficult to determine whether its even live
Fixes: 334
Cheers, @MisterW I did have my doubts, hence the question, and looking at it, I don't see it as a master socket either.
@KrazyyOne What is that to the right in the picture? I suspect the master socket is elsewhere.
Fixes: 459
The fact that the previous occupier left a filte suggests that the property hasn't got a filtere faceplate so all the sockets should work after a fashion, even if performance is degraded.
@jontysoper
Try reporting a fault, see https://www.plus.net/help/report-a-problem/broadband/#broadband
