How to keep interleaving off?
- Re: How to keep interleaving off?
25-10-2013 4:59 PM
All I know is that my ping gets me shot in the face a lot when playing COD. Im 35 years old and still play video games, I need all the help I can get, so a high ping doesnt help me beat these spotty teenagers.
Hope it can be switched off for good.
25-10-2013 5:01 PM
25-10-2013 5:07 PM
Interleaving is currently on albeit at the lowest level, I can place an order to turn this off if you wish although it wouldn't complete until Monday now.
just to add, it seems there's an order going through which is due to complete on the 31st that will hopefully remove interleaving for you.
25-10-2013 6:27 PM
26-10-2013 5:40 PM
28-10-2013 3:46 PM
I'll cancel this one off and get the order to turn interleaving off, probably won't be until Wednesday when interleaving is off.
29-10-2013 9:47 AM
04-11-2013 8:15 PM
05-11-2013 5:45 AM
05-11-2013 8:59 AM
I've placed an order for it to be removed again and I've changed some back end settings so that this shouldn't be enabled again.
@chesterfield
A ping of 40ms is actually really very good, I doubt you'd notice much of a difference between 20ms and 40ms. Interleaving is switched off on your line and that hasn't changed. I've made the same back end changes to ensure this does not get out on again.
07-11-2013 9:00 AM
Is there any particular reason why tests to pingtest.net should show 40ms+ when they used to show 14-17? Same router, same line, same ISP. No changes my end.
Just seen this in another thread from a user - average latency below 20ms...
07-11-2013 9:21 AM
I'm on 20CN less than a mile from the exchange, around 100 miles from London, 8192 down, 832 up (on Max Premium which also gives higher priority on the BT network), interleaving off.
Looking at my SamKnows monitoring stats it is currently showing around 18.5ms. When I lived in Sussex it was under 12ms.
07-11-2013 10:23 AM
[tt]ping bbc.co.uk
Pinging bbc.co.uk [212.58.251.195] with 32 bytes of data:
Reply from 212.58.251.195: bytes=32 time=26ms TTL=118
Ping statistics for 212.58.251.195:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 26ms, Maximum = 26ms, Average = 26ms[/tt]
07-11-2013 10:50 AM
How can I set one of these samknows monitoring thingys up then? Ill have a look on the samknows site.
All I know is that on wired ocnnections, I used to get 14-17ms pings on pingtest.net. Now its up around 40.
07-11-2013 12:06 PM
What's you sync speeds up and down and how far are you from the exchange?
