How to keep interleaving off?
- How to keep interleaving off?
18-09-2013 8:20 PM
Any advice greatly appreciated.
Re: How to keep interleaving off?
18-09-2013 9:51 PM
There's 3 options that we have regarding Interleaving:
- On
- Off
- Auto
Generally a line has Interleaving set to 'Auto'. This allows us to apply Interleaving just by doing a Line Reset (SNR Reset). We can place an order to turn Interleaving Off - this way the only way it can be turned on, if by us placing an order.
The 'On' option is pretty self explanatory - it means Interleaving is always on.
Please let me know if you'd like Interleaving switching off and we'll get an order placed
19-09-2013 10:06 AM
Yes please, I'd like it switched off. Until BT considers our cabinet "financially viable" and I can get fibre, then the couple of MB speed that I get extra with interleaving on is not really worth the frustration of the extra lag in games.
Thank you for your help.
19-09-2013 10:54 AM
I've just taken a look and there's an order progressing at the moment, I assume this was for moving you onto ADSL2+ or something similar. This order was due to complete on our suppliers systems on 25/09/2013 but I've amended this to complete tomorrow.
Once this order has completed, we'll get the Interleaving order placed which should complete at some point on Monday
Sorry for the delay.
19-09-2013 1:14 PM
19-09-2013 1:35 PM
19-09-2013 7:45 PM
Does Auto / ON mean increasing downstream sync rate but will increase ping and affect gaming online? As mine is turning OFF due to my important gaming online and low ping.
19-09-2013 8:11 PM
Interleaving shouldn't really make any difference to your sync rate at all. Interleaving only really 'Wraps up packets' to try and prevent packet loss. The amount of extra time it takes to do this, that is why you see an extra bit of latency on your connection.
Having ON will definitely increase the latency, but only by around 4-6ms (depending on the level of Interleaving applied). Being on Auto just leaves the DLM to make up it's own mind what it does with Interleaving.
Having Interleaving Off, will just mean there's no Interleaving.
I hope that helps.
19-09-2013 8:14 PM
19-09-2013 8:15 PM
15-10-2013 2:17 PM
17-10-2013 11:09 AM
It's still on at present but I've requested an SNR reset for you which should turn it off. Hoping it's alright without interleaving with a 3dB downstream SNR target, it should be.
Let us know if it doesn't work, should take effect within the next few hours.
24-10-2013 10:34 PM
Is interleaving off now? Can it be kept off? Pings seem very high still and lag in online games seems an issue.
24-10-2013 10:59 PM
You can see both photo before and after (interleaving option) below
25-10-2013 8:50 AM
The only way to tell for sure is to look at what the router tells you. Does it say fast or fast path? Look at the error counts if there any FEC errors logged interleaving is on.
