How long does interleaving take to be switched off from request?
- Re: How long does interleaving take to be switched...
Re: How long does interleaving take to be switched off from request?
01-03-2009 10:48 AM
Synced @ 5088 with a 6.1db noise margin currently,one question is if i stay on my current 4Mbps profile and with my sync at 5088 will i see any difference in throughput?
Max download rate i get is 475 kB/s,have done since before joining PN,know i might be greedy in wishing for more but hey,it`s my birthday soon :D.
01-03-2009 11:35 PM
The IP profile is an idealised throughput speed and the maximum real speeds, which allow for transmission management (handshaking, buffering, receipt acknowledgement, maybe a few retransmissions), will be lower than that by 2-300kbps. 4000-200=3800kbps which is 475kBps the value you mentioned. So the speeds you actually see look about right.
05-03-2009 6:30 PM
Jameseh,my noise margin has gone up to 9db now interleaving is back on,used to hover around 6db before i had it switched off and profile is 3500 kbps now.
Is it a case of waiting for the line to sort itself out or shall i lower my noise margin on the router here or would you do it your end?
05-03-2009 6:34 PM
If you can lower the noise margin on your router using DMT, then by all means give it a shot.
I suspect your connection is now stable because of the interleavinf AND the noise margin.
05-03-2009 6:44 PM
I`ll drop it down to 6 then,thanks jameseh.
06-03-2009 5:14 PM
Not had my connection do that before i dont think,is it normal when going back onto interleaving or would it indicate a problem?
07-03-2009 5:44 AM
You say you lost sync. Are you graphing and saving the DS sync with RouterStats as well as Noise Margin?
It would be helpful if you could post the graphs for the period in question. I might be inclined to leave your Target SNRM alone for a while until any problems are solved, otherwise the DLM may raise it further!
Do you have any extensions or extension wiring, if so check that the bell wires are disconnected (orange/wh & wh/orange on terminals 3 & 4) on rear of master faceplate as well as at extensions.
07-03-2009 8:43 AM
07-03-2009 3:40 PM
If you set RouterStats to Capture & save always, it'll save your required graphs to your designated folder as .jpg 's every period. I'd set the number of points per page lower, to give you a shorter time scale and more detail. What rate are you sampling at? A default of 8 secs should be OK.
The jpg. you can attach to your post by using the "Additional Options..." below the reply window, easier to do, easier to access for readers.
07-03-2009 6:36 PM
Ok,set routerstats up as suggested,only had the graphs set to show a long period of time to show what was happening,usuall have it set @ 100 points per page (every 13 mins i think it is).
Well,hopefully i should have my profile back to 4,000 kbps soon then.
07-03-2009 10:14 PM
Once RS is set running it automatically saves every 2 hours.
11-03-2009 6:44 PM
Would it have to be a constant connection to switch back onto it or a sync not dropping below a certain rate e.g 4608?
Jameseh,can someone have a looksee and see how my connections been since sunday please?
11-03-2009 7:03 PM
heres a table of the sync you need to keep above for what profile.
sync profile
from 288kbps up to 0.25Mbps
from 576kbps up to 0.5Mbps
from 1152kbps up to 1Mbps
from 1728kbps up to 1.5Mbps
from 2272kbps up to 2Mbps
from 2848kbps up to 2.5Mbps
from 3424kbps up to 3Mbps
from 4000kbps up to 3.5Mbps
from 4544kbps up to 4Mbps
from 5120kbps up to 4.5Mbps
from 5696kbps up to 5Mbps
from 6240kbps up to 5.5Mbps
from 6816kbps up to 6Mbps
7392kbps up to 6.5Mbps
7968kbps up to 7Mbps
8128kbps up to 7.15Mbps
http://www.plus.net/support/broadband/products/faqs_and_guides/dslmax_guide.shtml
have you checked the member centre line profile for your line and the bt speedtest that tells you your profile. if these have both increased to 4000kbps make sure you disconnect the internet through your router setup pages and reconnect for the profile to take effect on your line
11-03-2009 9:21 PM
Download Speed: 3787 kbps (473.4 KB/sec ) Upload Speed: 371 kbps (46.4 KB/sec ) on BBmax speedtest.
12-03-2009 6:23 PM
After rebooting saw i was still on a default 9db noise margin,whereas i was 6db before having interleaving switched off originally.
Dropped it back to 6db via routerstats this morning,just got home and checked things out and noticed my profile change.
Know i have to wait another 3 days before syncing back,but is there anyother way of setting my default nm back to 6db?
