How do I get a New Router?
globalbagtag
Been with Plusnet for years but my router has never been updated, I tried to call support twice to ask about one but both times there was a 40min wait time!
3 REPLIES 3
Gel
Aspiring Champion
Fixes: 29
Re: How do I get a New Router?
You can normally negotiate one free of charge at contract renewal time, but plenty on E Bay, including PN ones.
Mads
Fixes: 79
Hi @globalbagtag,
Thanks for getting in touch. As @Gel has mentioned we can send you out a new router (£6.99 p&p charge) at the time of contract renewal. If there is an issue with your services in terms of speed/connection please get back to us on here and we can look further into it for you.
Fixes: 420
If you're on standard broadband all Plusnet will offer is a Hub Zero. I fear that you will find little or no difference in performance with that which you already have, presumably a Technicolor unit.
If you want a better router for little money then spend around £30 on Ebay and get a BT Smarthub 6. You will find the simple setting instructions in this forum.
