House move x2
- Re: House move x2
Re: House move x2
18-05-2009 3:47 PM
But, thikning about it, wouldn't many others also be reporting such issues as it can't be a one-off as I have tried two?
Edit: I may still have my old SAR130 - it's a modem and not a router but would that help in any way? I'll see if I can find it.
Forum Moderator and Customer
Re: House move x2
24-05-2009 7:44 PM
I have purchased a second-hand DG834G v3 from ebay. If this helps maintain a more stable and higher synced line then I'll probably buy a new one. BTW once received should the firmware be updated?
Meanwhile it resynced this moring from 5358 to 4686 but UL increased slightly to 1032.
Att has remained at 45dB but S/N has increased to 9 where it had been at 6-6.5 for the last week.
Still concerned at syncing so low when someone in this thread (also on 21CN) is syncing much higher but with a ATT only marhinally lower than mine!
Also, if it is a problem with the Thompson 585 per se how come there doesn't seem to be anyone else experiencing the same - at least, not here?
Thanks agin for all the support
Re: House move x2
27-05-2009 3:36 PM
But, is there anything I should know specifically to setup this router with PN?
Re: House move x2
27-05-2009 3:40 PM
It's all generic settings apart from your username and password. It should be relatively easy to setup.
Was there no insert sheet inside the box?
Re: House move x2
27-05-2009 3:50 PM
I would have thought it is simple enough - just wondered how I can ensure it's configured for ADSL2+. The manual I dl'ed doesn't show this and a Google search hasn't yet been successful
Re: House move x2
27-05-2009 4:03 PM
If you want to use Netgear firmware make sure it has the latest version for proper ADSL2+ support.
Re: House move x2
27-05-2009 4:37 PM
Re: House move x2
27-05-2009 5:32 PM
The high FEC levels seems to appear suddenly between 5 & 10 minutes after a reboot then never increase after that.
That's one of the reasons I got the netgear to see if it's a line problem here or the router.
NetGear connected, factory reset, blah, blah and all is well and even got the wireless part to work first time
Stats so far:
Quote ADSL Link Downstream Upstream
Connection Speed 4998 kbps 1004 kbps
Line Attenuation 46 db 13 db
Noise Margin 9 db 6 db
I now need to find my way around the Netgear to get all the relevent info and set it up with RouterStats. Can't see, yet, where the reported FEC and other such errors can be found or how to ensure it is set for ADSL2+.
As previously mentioned, I am certain I should get a much higher sync rate with an Att of 46 as have some others with similar stats.
Edit: Forgot to mentioned I have upgraded to latest firnware - v4.01.40.
Re: House move x2
27-05-2009 6:13 PM
Quote from: Mav Can't see, yet, where the reported FEC and other such errors can be found
On the Telnet pages of RouterStats (setting that up is a doddle for a Netgear).
Re: House move x2
27-05-2009 6:25 PM
Probably be sometime tomorrow, tho'.
Cheers all
Re: House move x2
27-05-2009 6:59 PM
I am assuming that the URL of the 'stats page' is the small window that opens when you click on 'Show Statistics' from the Router Status' page?
Having copied and pasted the URL no results are shown & GetPage appears to do nothing - not even an error (I have entered the correct ID and password for the router).
Edit1: Tried versions 5.0c, 5.1c & 5.2e
Edit2: OK - solved - seems I should have left the URL to the default - now using 5.2e
Re: House move x2
27-05-2009 8:13 PM
What other graphs would be needed to ascertain if and where any problems/issues lay?
Edit: Added a more recent DL S/N graph.
Re: House move x2
28-05-2009 7:29 AM
Re: House move x2
28-05-2009 2:28 PM
Meanwhile, I have uploaded a pic of the Telnet summary showing that I am still getting high FEC errors (currently almost 1200 per sec) - the up times is a few minutes over 6 hours. THis, possibly, rules out any issue with the Thomson?
Re: House move x2
29-05-2009 10:29 PM
Firstly, I disconnected all phones and router and plugged a non-DECT phone into the master socket. I could hear a faint hiss but nothing too loud.
Then I plugged the BT MF50 filter into the master socket and then just the phone and heard a faint buzz. Added the router and still the same.
I then disconnected the BT MF50 and used the original D-Link filter (mentioned previously) and just got the faint hiss which was the same with the router plugged back in.
I have now left the D-Link filter connected.
The last reconnected of the router caused it to re-synced at a low 4688 whereas I was synced at just over 5000 when I rebooted this morning.
The latest S/N from Router Stats is attached.
Hope the above is of some help.
