Here we go again :-(
- Here we go again :-(
- « Previous
- 1
- 2
- Next »
Re: Here we go again :-(
23-07-2013 9:12 AM
Yes, it should do - it can take a while though, so as long as it stays stable for a couple of days then we can reset the line and let it retrain at its best possible speed.
Message 16 of 19
(174 Views)
23-07-2013 9:13 AM
Thanks.
Hopefully it will be here today. Is it worth putting the ASDLNation filter on at the same time?
Message 17 of 19
(174 Views)
23-07-2013 6:00 PM
Have fitted new router and ADSLNation faceplate. Modem now connects and uploads. Line speed only 6 meg now. Was 7.4meg before and ping back to mid 40s and speed about 4.9mbps from 6.16 before the faults.
FEC errors low at the mo. Will see how it goes but can someone monitor my connection in lieu of resetting the line to get speeds back?
Message 18 of 19
(174 Views)
23-07-2013 8:30 PM
Still ok after 2 1/2 hours.
Here are the stats:
DSL Connection
Link Information
Uptime: 0 days, 2:39:53
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 1,083 / 6,083
Data Transferred (Sent/Received) [MB/MB]: 23.73 / 297.02
Output Power (Up/Down) [dBm]: 12.7 / 0.0
Line Attenuation (Up/Down) [dB]: 27.9 / 49.5
SN Margin (Up/Down) [dB]: 5.4 / 7.4
Loss of Link (Remote): -
Error Seconds (Local/Remote): 524 / 0
FEC Errors (Up/Down): 327 / 157,174
CRC Errors (Up/Down): 56 / 1,293
HEC Errors (Up/Down): 35 / 16,470
The SNR is up. Was as low as 2.4 last time. Is higher better on the SNR down?
Will my speed increase now....purlease
Here are the stats:
DSL Connection
Link Information
Message 19 of 19
(174 Views)
- « Previous
- 1
- 2
- Next »
