Help needed for novice
- Re: Help needed for novice
- « Previous
- Next »
03-08-2012 5:31 PM
It could be the router, it is a process of elimination, but it will help rule your phone line out. The only way to definitely see if your router isn't working is trying another.
Your line has become more stable over the past day compared to the past week.
It appears you have closed your fault that was open, if your conenction does drop again I'd suggest raising a fault again at http://faults.plus.net
Chris
Chris
Message 31 of 33
(120 Views)
03-08-2012 5:32 PM
I suggest you try a silent line test I think you dial 17070
To do is to be - Neitzsche
To be is to do - Kant
do be do be do - Sinatra
Message 32 of 33
(120 Views)
03-08-2012 5:34 PM
and choose option 2 - quiet line test.
do it on a wired phone - not a 'dect' portable
Message 33 of 33
(120 Views)
- « Previous
- Next »
