Help me boost my speed :)
- Re: Help me boost my speed :)
11-08-2015 8:17 PM
Hello
As I am finally live with PlusNet (for a whole 4 hours), I went to check speeds:
BT Wholesale result: 7.5 down, 0.99 up. didn't let me run advanced
Router stats:
STATISTICS
Interface Transmit Receive
Frames Bytes Collision Error Frames Bytes Collision Error
LAN: 62640 18601768 0 0 0 0 0 0
WAN:
367828 30547778 510 0 404825 250540079 1157 887
Wireless: 461519 256374393 - 1069 386312 39647601 - 25982
ADSL STATISTICS
Line State up
Modulation ITU G.992.5(ADSL2PLUS)
Annex Mode ANNEX_A
Downstream Upstream
SNR Margin 6.1 dB 6.6 dB
Line Attenuation 24.2 dB 12.2 dB
Data Rate 15501 kbps 1167 kbps
ES 16473 0
SES 2677 0
UAS 89 89
FEC 0 0
CRC 33447 0
PlusNet Membercentre info:
Estimated line speed:
15Mb (This may vary between 8.5Mb and 19Mb) - Checked on 2015-07-16 14:01:37
Current line speed:
7.15 Mb
Overall a bit lower than I had with TalkTalk on the same router on the downstream data rate / estimated line speed.
Concerned about the Current Line Speed bit though, as that's actually 50% of the total?
No Noise on the phone line at all
Router stats:
STATISTICS
WAN:
ADSL STATISTICS
Line State up
Annex Mode ANNEX_A
Downstream Upstream
ES 16473 0
SES 2677 0
UAS 89 89
FEC 0 0
CRC 33447 0
Current line speed:
7.15 Mb
Message 1 of 4
(712 Views)
3 REPLIES 3
12-08-2015 10:34 AM
Hmm, for some reason the supplied product on our side had been set to an up to 8Mbps one. I've corrected that now, can you disconnect/reconnect and see what the speeds are like now?
Message 2 of 4
(460 Views)
12-08-2015 1:28 PM
Seems better, thanks
Current line speed:
13.6 Mb
STATISTICS
LAN: 3068 651336 0 0 0 0 0 0
WAN:
4926 1244895 440 0 5198 3462972 0 0
Wireless: 8052 4402038 - 21 10001 1507140 - 646
ADSL STATISTICS
Line State up
Annex Mode ANNEX_A
Downstream Upstream
SNR Margin 6.3 dB 6.5 dB
Data Rate 15853 kbps 1159 kbps
ES 1 0
SES 0 0
UAS 89 89
FEC 0 0
CRC 1 0
Current line speed:
13.6 Mb
STATISTICS
WAN:
ADSL STATISTICS
Line State up
Annex Mode ANNEX_A
Downstream Upstream
ES 1 0
SES 0 0
UAS 89 89
FEC 0 0
CRC 1 0
Message 3 of 4
(460 Views)
12-08-2015 6:34 PM
Could someone help me understand the error bits and whether that is good/bad?
Also, the attenuation bit, is that rather high or am I reading the wrong part?
Message 4 of 4
(460 Views)
