Usage data
chad5k1
Usage data
I can't get access to my usage data, it says it can't display anything.
That is a shame as I really need to see how much data has been used in each of the last few months.
Any suggestions?
thejudge
Re: Usage data
I've had this problem for at least a year. I raised a 'question' months ago, but nothing has been forthcoming.
chad5k1
Re: Usage data
That sucks, I could really do with this data and I used to have it.  It disappeared recently - if I'd have know I would have kept a log!
Fixes: 165
Re: Usage data
Hi chad5k1,
I can give you a monthly summary if you like?
 Chris Parr
 Plusnet Staff
Fixes: 165
Re: Usage data
I've just popped the summary for the last few months on your account here
 Chris Parr
 Plusnet Staff
chad5k1
Re: Usage data
Thanks, that is great!
I have June and July listed, do you have any earlier months too please?
Fixes: 6
Re: Usage data
Chris, any chance you could pop mine on a ticket as well please?  I've not been able to access it for a long time, and have had no luck getting it reinstated when I've asked.
Phil
Fixes: 165
Re: Usage data
@chad5k1
I've only been able to pull 1 more month. I've added that here
 Chris Parr
 Plusnet Staff
Fixes: 165
Re: Usage data
@pjmarsh Just taking a look now.
 Chris Parr
 Plusnet Staff
Fixes: 6
Re: Usage data
Thanks Chris.  I've just seen the ticket notification.
Phil
Fixes: 165
Re: Usage data
No worries, I went back to May as that's normally as far as you'd be able to see anyway.
 Chris Parr
 Plusnet Staff
