Have I switched over?
- Re: Have I switched over?
- « Previous
- 1
- 2
- Next »
07-08-2012 4:21 PM
Quote from: MisterW It looks suspiciously like its been provisioned on 21CN but capped to an ADSL1 profile ( i.e max 8124k ).
Yup
I'd agree with you on this one.
Message 16 of 23
(376 Views)
07-08-2012 4:25 PM
It has been placed on ADSL1 but this is in the process of changing over to ADSL2+.
Message 17 of 23
(376 Views)
08-08-2012 8:09 AM
Looks like the changeover of profile happened.
Just tested my download and it's showing up at 6.57 with an upload of .71.
Will this increase?
Stats this morning:
Uptime: 0 days, 2:33:38
DSL Type: G.992.5 annex A
Maximum Bandwidth (Up/Down) [kbps/kbps]: 888 / 21,388
Bandwidth (Up/Down) [kbps/kbps]: 888 / 19,715
Data Transferred (Sent/Received) [MB/MB]: 10.76 / 14.67
Output Power (Up/Down) [dBm]: 12.0 / 20.0
Line Attenuation (Up/Down) [dB]: 6.5 / 15.5
SN Margin (Up/Down) [dB]: 15.0 / 6.0
Loss of Signal (Local/Remote): 65,538 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 65,538 / 0
FEC Errors (Up/Down): 0 / 16,287
CRC Errors (Up/Down): 0 / 5
HEC Errors (Up/Down): 0 / NA
Will this increase?
Stats this morning:
Message 18 of 23
(376 Views)
08-08-2012 11:22 AM
I've tested your line and it's showing your speeds are now around 17MB/s. From your router stats it appears you are also getting the faster speeds. What speed are you currently getting? It should be faster that 6.57MB/s. If possible try another speed test. If this still hasn't improved, login to your router, disconnect and then reconnect and test your speeds again.
Chris
Chris
Message 19 of 23
(376 Views)
08-08-2012 11:31 AM
Well that did it it's around 11 now and I'm running a few internet hogging programs....Chers for the help on this one.
Great service from plusnet.
Message 20 of 23
(376 Views)
08-08-2012 1:05 PM
No worries, your certainly on ADSL2+
Give me a shout if there's anything else.
Chris
Chris
Message 21 of 23
(376 Views)
10-08-2012 8:35 AM
Just wanted to report that i logged in this morning and my speed has again been bumped up...sitting on just over 20mb down and 1mb up now.
Did an actual speedtest and it produced 18mb and 1mb....thats 3 times as fast as I was getting before the 21CN switch! AMAAAAZING.
Thanks very much for this Plusnet...very impressive.
LB
LB
Message 22 of 23
(376 Views)
10-08-2012 11:01 AM
That's great news, nice one Glad you're happy with the connection, hope it stays that way.
Message 23 of 23
(376 Views)
- « Previous
- 1
- 2
- Next »
