Have I switched over?
- Have I switched over?
07-08-2012 8:36 AM
When I logged in the morning my router gave the information below.
Given the max Bandwidth...has the switchover been made?
Also, given the line stats attenuation/noise e.t.c is this considered a strong connection and should i get near on 21mbs?
Link Information
Uptime: 0 days, 14:29:14
DSL Type: G.992.5 annex A
Maximum Bandwidth (Up/Down) [kbps/kbps]: 888 / 21,592
Bandwidth (Up/Down) [kbps/kbps]: 440 / 8,124
Data Transferred (Sent/Received) [MB/GB]: 196.03 / 2.52
Output Power (Up/Down) [dBm]: 12.5 / 18.0
Line Attenuation (Up/Down) [dB]: 6.5 / 15.5
SN Margin (Up/Down) [dB]: 30.0 / 14.0
Loss of Signal (Local/Remote): 3 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 4 / 0
FEC Errors (Up/Down): 0 / 1,863
CRC Errors (Up/Down): 40 / 0
HEC Errors (Up/Down): 0 / 0
Re: Have I switched over?
07-08-2012 9:09 AM
07-08-2012 9:19 AM
Your line has transferred over to ADSL2+ today, your IP profile now needs to update and this should be completed by midnight. You will then see your increased speeds.
If you have any questions, please let me know.
Chris
07-08-2012 10:13 AM
Aslo, given the stats above, what sort of speeds could i expect after the bedding in time?
Cheers.
07-08-2012 10:16 AM
07-08-2012 10:24 AM
If for any reason you don't see the improvement, let me know and I'll get that sorted straight away.
07-08-2012 10:29 AM
07-08-2012 1:11 PM
So why is the sync speed at only 8124?
At 15dB downstream attn' it should be much higher.
The downstream noise margin of 14 is also very high
So either the target margin has been set at 15 for some reason and this is restricting the sync
or it is being capped at 8124 for some reason
or both
(I've seen this 8124 figure mentioned before on these forums re ADSl2+.......)
A 15 d/s attn and 6 target margin should give a sync around the 20K+ region, an IP setting of around 17 as 'CP' says.
but that ain't going to be achieved with a sync of 8124
07-08-2012 2:00 PM
Quote from: LuthersBoots Maximum Bandwidth (Up/Down) [kbps/kbps]: 888 / 21,592
What is the difference between these 2 lines?
07-08-2012 2:04 PM
But I am not sure what both of the last two replies are on about???
07-08-2012 2:15 PM
Quote from: BRABUS Bandwidth (Up/Down) [kbps/kbps]: 440 / 8,124
This is showing what your profile is set to, that is why you haven't reached the higher speeds yet, it is still on the ADSL1 profile.
07-08-2012 2:17 PM
Cheers
LB
07-08-2012 2:19 PM
07-08-2012 2:25 PM
Quote from: chrispurvey Hi Lutherboots.
Chris
07-08-2012 2:56 PM
