Getting IP Profile up
- Re: Getting IP Profile up
26-07-2012 9:39 AM
I am getting 234/331 Kbps, consistent with my IP Profile of 0.25 when I last looked. I assume I should switch the modem off every night and switch it on again in the morning to try and get the IP Profile to lift. Is there a way to make this happen more quickly? I am likely to get similar problems again (had one two months ago) as I am the victim of BT's decaying infrastructure (along with many others according to the BT engineer).
26-07-2012 9:55 AM
26-07-2012 10:19 AM
26-07-2012 10:30 AM
If the outage has left your line 'stuck' on a low sync but it is stable then PN could try a 'SNR reset' but they will need to see a stable connection.
26-07-2012 11:32 AM
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13432980979158.png" />
We need to resolve this issue that will then in-turn get your broadband speeds back to normal.
You've started the fault process, if you could complete the initial diagnostic questions then we can get this looked into and identify why this is happening. I'd suggest leaving your router turned on and also connected into your <a href="http://www.plus.net/support/broadband/master-socket-guide.shtml/">test socket</a>.
26-07-2012 11:37 AM
Especially on longer and/or "awkward" lines, the recommendation is to leave the modem/router on 24/7. When/if you have a stable line you will recognised the (usually small) range of sync speeds that you should get when things are performing correctly. For a given sync speed your IP profile for the line can be seen here for 20CN and for 21CN it's 88.2% of sync speed.
As you probably know, you can confirm the IP profile for the line by running the BT Speedtester (Diagnostics) and also check your Current Line speed which should match.
If you have a low sync event due to a fault, or burst of noise or static(lightning), once that has cleared a resync should recover your sync speed to normal levels. You do need to check if you have a low sync and reboot if that's happened. On 20CN, however, the profile doesn't recover immediately and can take around 3 days and it's best to leave the modem/router on 24/7. Further resyncs can slow down the process.
On both 20CN & 21CN the Plusnet Current Line Speed should recover within 12 hours or less, but doesn't always do so and sometimes needs a kick.
If you still have a crackly phone line (even intermittent) you need to report that to your line rental provider,. preferably when it's crackly, get them to confirm they can hear it and note that it's intermittent, and get then to run a line test. Don't mention the broadband otherwise you can get the run around.
26-07-2012 3:17 PM
26-07-2012 3:21 PM
27-07-2012 6:59 AM
27-07-2012 11:56 AM
Let me know, it can take 72 hours for your IP profile to manually reset itself, but placing the SNR reset will set the IP profile to what is deemed acceptable for your line stats and stability.
27-07-2012 11:25 PM
I only have the modem and a steam phone attached. I'm on my third filter. Nothing was happening and the dial tone was noise free. I can't imagine why the broadband collapsed. It was connecting at about 25 Kbps but now is back up to 234/331 Kbps. Incidentally why do BT use 0.25 when they can see a 0.331 channel working?
I'm thinking the only solution is to buy a second line. They'll have to put some new copper in. I'm not accepting mulitplexing.
29-07-2012 8:59 AM
I'm still stuck on 0.25. It doesn't look like BT are going to lift this automatically. Do I have to raise a ticket?
30-07-2012 3:29 PM
Looking at the logs it seems there were a couple of connection drops that aren't necessarily serious in themselves however they have most likely kept the profile at its current level (depending on the sync speed your router achieved when connecting up afterwards).
Your current connection is ongoing for over 24 hours though, I'd say if it stays up overnight and the profile hasn't uplifted tomorrow we'd be able to do an SNR reset which should sort things out for you.
31-07-2012 2:59 PM
Just re-booted in the test socket and I'm still on 0.25 Mbps. Should I raise a ticket?
31-07-2012 4:21 PM
If possible just leave your router turned on. As your line will need to settle.
Let me know how you get on.
Chris
