Speed Issue - What Now?
khaled35
Well, on the 31st of July, my connection dropped for 2 whole days.  Half way through day 3, it sync'd off it's own accord.  Since then, my usually very stable 1500 - 1800 kbps downstream has dropped to just about 180kbps.
Two engineer visits later, my router now reads a downstream of about 4500kbps BUT ... here's the kicker ... my throughput is just about 200 - 220 on every speed test I have used.  Here is the info from the BT wholesale speedtester:
Download speedachieved during the test was - 0.06 Mbps
For your connection, the acceptable range of speeds is 1.2 Mbps-4 Mbps.
IP Profile for your line is - 3.68 Mbps
I am at wits end since this issue has been ongoing for nearly 3 weeks now with no real end in sight.  If any Plusnet Staffers want to look into my issue, my username is khaled35 - it would be greatly appreciated.
Regards
Re: Speed Issue - What Now?
https://portal.plus.net/my.html?action=data_transfer_speed if that and your IP profile don't match and the PN one is stuck, then raise a ticket and get it changed
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
khaled35
Hi Gus,
The details on the page you linked to state:
Estimated line speed:
Not recorded (service activated before we introduced estimates).
Current line speed:
0.25 Mb
I do have a support ticket ongoing since 31st July and was even on the phone with PN Support this morning.  You'd think they would check this for me and get it sorted?  I've been patient for near on 3 weeks but I am feeling my patience running out.  I'll give it until Monday and give them a final call then and see what happens.
Cheers
Time to phone them again and tell them the BT IP profile the plusnet profile don't match, as that is why you have poor speeds currently
khaled35
Well, my issue still remains unresolved.  When I run the BT wholesale speed test, I see this:
When I look at my IP profile on PN, I see this:
Current line speed:
0.25 Mb
Called PN Support to ask that my PN profile be changed to match BT's and I am told that BT's IP Profile for me is also 0.25.
I honestly don't know what to do next.  They keep telling me to wait 48-72 hours and I'm concerned that if my PN IP profile is indeed stuck, waiting this extra time won't really help in any way.
Fixes: 55
Sounds like you might have a profile mismatch on BT's systems. I'm sure one of the Digital Care Team will be along shortly ( they don't work weekends! ) to sort it out.
Fixes: 24
Quote from: khaled35
This looks like a failure of Plusnet's records to be updated properly.  Hopefully someone will deal with this promptly because failures of this type knock a big hole in Plusnet's reputation for good customer service.
khaled35
I hope one of the PN Staff that frequent this forum are able to help because it doesn't seem like I'll ever get a resolution speaking to their frontline support people.  I'm basing this prediction off 3 weeks of personal experience Smiley
In any case, this is what my Vigor 120 reports:
ADSL Status
Mode: ADSL2+(G.992.5)
State: SHOWTIME
Up Speed: 444937
Down Speed: 4259139
SNR Margin: 12
Loop Att.: 46
This is all so very very strange.  Router reports a downstream of 4Mbps, BT IP Profile states about 3.68, PN states IP Profile as 0.25 - so is it safe to assume that once PN change my profile on their end, everything should work correctly?
khaled35
FINALLY got someone on the phone who was either willing or able to help.  My issue is now resolved.
Thank you to everyone that replied with suggestions; much appreciated.
