Frequent dropouts 25th Jan 2025
Fixes: 236
Re: Frequent dropouts 25th Jan 2025
That wound be fine if the devices were compliant with the standard. Given the improvements you’ve seen by increasing the cable distances, it would be fair to infer that one or more devices are not compliant with the BS standard.
The quoted reference also refers to Low Voltage not mains voltage.
Madeleyite
Fixes: 6
Understood. I am happy with the speeds now and up to now stability has been fine with no dropouts. I just posted for information purposes only. I'll leave the room now. Just thought it useful to know.
I believe the BS 6701 applies for voltages below 300v AC. See photo copied from Computer Active magazine.
Fixes: 236
I have had degraded switched current PSUs blast RFI over several metres.
I think that the standard refers simply to the proximity of clean power cables, which would be quite reasonable.
Thank you for clarifying the LV reference to be sub 300V.
Do not leave the room all input is helpful, though I do not think in context the standard challenges your history. The excellent work you did in moving the PSUs appears to have delivered a marked improvement in stability and performance.
grumble
Transformers - interference in disguise.
Madeleyite
Fixes: 6
It is now 84 days since the last dropout so I will call this thread fixed now and leave the room.
Thanks for all input. 😀
