Frequent Drop-Outs
Dodeth
Frequent Drop-Outs
Over the last few days my connection is dropping out on a very frequent basis. I think I've tried out all the recommended fixes, but to no avail.
Any advice?
13 REPLIES 13
Fixes: 387
Re: Frequent Drop-Outs
@Dodeth It is possible you have a BT/OR network problem, but without some solid data to work with, it is difficult  to make suggestions. As a start, which modem/router are you using? and if you provide the information requested below, we may be able to point you in the correct direction.
BT Broadband(obscuring your phone number) and BTW Performance Tester - Over a wired (ethernet) connection if at all possible, please report the 'ADDITIONAL DIAGNOSTICS', and sight of the broadband connection status from your Hub (with the 'Username' obscured) would be a good starting point.
For the Hub One -
For the Hub Two -
If phone test is OK then take the front off your telephone master socket, you may need to remove two screws. In behind you will find the test socket. Plug a filter in here and connect that to your hub. If it’s still dropping out then say so.
Dodeth
OK. The first thing to say is that my download/upload speeds are way down from where they should be. I've tried to post the two bits of info you requested but I can't work out how to place the screen shot within the topic. I've also done the quiet line test and there was no discernible noise (although my hearing isn't great!).
Fixes: 387
OK, to post those screen shots, save them somewhere (My Pictures is the obvious place, to me), then click the icon to the right of the 'smiley' above the text box and follow the prompts, insert the first picture, then repeat for the second one. Until er have some solid data to work on, I can't really comment further.
Dodeth
It's Hub 1, by the way.
Dodeth
I know I'm extremely stupid but how do you save a screenshot?
Fixes: 387
Not  stupid. To save a screen shot - right-click it, and you should get a pop-up with options, which will guide you. Don't worry about asking questions - I'm happy to help those who want to help themselves.
Dodeth
Dodeth
Fixes: 387
That first screen shot shows a potential problem - most likely in the BT/OR network, but we do  need the other data as well, please.
Dodeth
Thanks John. I'll have to pick this up tomorrow as I'm being called for dinner!!
Fixes: 387
OK, no problem - I'm around from 7.30 AM approx to 8PM.
@Dodeth
If it helps there is a 'snipping tool' which allows you to capture parts of a screen.
If you click on Start and type 'snipping' you should see
Open the app and you will see
Click on new, using the mouse select the area of the screen you wish to capture and then save.
HTH
Fixes: 1,662
I see we've booked an engineer visit for tomorrow afternoon.
Let us know how it goes.
