Flashing orange light
- Flashing orange light
28-03-2025 3:03 PM
Re: Flashing orange light
28-03-2025 3:07 PM
28-03-2025 3:16 PM
28-03-2025 3:21 PM
FTTC is Fibre to the cabinet, meaning your connection is delivered over the existing copper wires and you connect to the existing Openreach master socket, This product is confusingly called 'Fibre'.
FTTP is Fibre to the premises, Openreach will install a completely new cable (Fibre optic) to your house, and will install an ONT (Optical network termination) unless the property already previously had FTTP, this is called 'Full Fibre'
Which product have you ordered ? and have you received an email to say its been activated
28-03-2025 4:13 PM
28-03-2025 4:35 PM
Is your Plusnet Hub connected from the DSL port to the Openreach master socket ?
does the socket look like this ?
