No internet connection
Sueanne
Internet just disconnected as I was watching tv, all lights showing as should. Have done all the troubleshooting tips but still nothing. Only joined yesterday.
24 REPLIES 24
Fixes: 380
Re: No internet connection
@Sueanne When you 'Internet just disconnected' what exactly do you mean? Are you on an FTTC or Full Fibre connection?
Sueanne
I just know that I have a plusnet hub 2, no phone line. And it just said no internet connection and won’t reconnect
Fixes: 380
Can you access your Hub2 ? Don't take this wrong - it is just so I and others know which questions to ask and how to ask them - but how 'technical' are you?
Sueanne
Plusnet hub 2 manager comes up on the screen when I try to connect and not that technical really
Fixes: 380
OK - what are you using to post at the moment - a phone or a tablet on data?
Sueanne
I’m using my phone on data
Fixes: 380
OK. Sorry, I'm going back to basics here - Is your Hub2 connected into your telephone maser socket? Exactly what troubleshooting have you done? Does the Hub manager look like this:
Sueanne
It’s in the master socket and it looks like that apart from it’s all pink
Sueanne
Turned off and on, factory reset also, checked all cables
Fixes: 380
Right, so we now know you are on an FTTC connection - good.
Fixes: 380
@Sueanne 'its all pink' - that sounds strange. 😕
What does it say in the first box on that screen?
Sueanne
Broadband status connected. But it is definitely not working
Fixes: 380
Again, sorry for asking so many questions, but if you have a laptop/computer and try using that, what happens?
Sueanne
Laptop says no internet access
