Fitted a adsl nation faceplate filter can you check my line
- Re: Fitted a adsl nation faceplate filter can you ...
22-11-2011 1:29 PM
Hi I have just fitted a adsl nation faceplate filter all seems ok but my phone has got a intermittent dial tone the phone works ok is this normal could someone at pn check to see if the filter is working ok thanks
Message 1 of 5
(989 Views)
4 REPLIES 4
Re: Fitted a adsl nation faceplate filter can you check my line
22-11-2011 1:43 PM
What is the "intermittancy"? you havent got a voice-mail waiting have you?
To do is to be - Neitzsche
To be is to do - Kant
do be do be do - Sinatra
Message 2 of 5
(440 Views)
22-11-2011 2:10 PM
Message 3 of 5
(440 Views)
22-11-2011 2:14 PM
HI rodtrotter,
Try dialling 1571 and see if you have a message, the behaviour you describe is what I would expect to see when you have a message in your voicemail.
Jojo
Jojo
Message 4 of 5
(440 Views)
22-11-2011 2:37 PM
That's spooky I have never had voicemail setup but it is now and yes I had two messages
Message 5 of 5
(440 Views)
