The early bird catches the worm!
caulbox
Am I free to go back to sleep now?
pierre_pierre
Re: The early bird catches the worm!
who did you catch?
caulbox
The Ghost in the Machine
caulbox
Curioser and curioser? Might be coincidental to the story of my usage (or of my life - so probably not), but I think I've also just caught "a fish alive" in the pools as well. I rarely if ever get SPAM, but I got this message sent at 8.49 a.m. this morning from "Littlewoods" to "undisclosed-recipients"
Dear Valued Customer,
To protect your account, Your access to our internet service has been
suspended,
In order to regain access to our internet service, you are required to verify
your account security details to our new security system.
Click here to verify your account, And make sure your security details are
filled correctly.
Sorry for the inconvenience,
We hope you find our Internet service easy and convenient to use.
Yours sincerely
Littlewoods.
** the click here link in the message - which I've manually typed below and edited with a DUMMYWORD to prevent others from inadvertantly clicking leads to a Ukrainian destination:
http://DUMMYWORDweb.mstreet.com.ua//img/littlewoods.com/login.pagefrom=myAccountStatus.htm
Still curious about this, but (cautiously) Googling 'Littlewoods' and 'mstreet' does find some ongoing live updating and grounds for suspiscion in the PhishTask
....back to counting sheep for now!
Fixes: 162
Sorry but I'm not actually sure what you're getting at here?
Is it that usage is being accrued when you're not using the Internet? As from your screenshots you were using the Internet to look at our website so I'd expect a small amount of usage (which is exactly what was shown).
The mail as far as I can tell is unrelated to us and looks to be obvious spam.
 Chris Parr
 Plusnet Staff
caulbox
Quote from: Chris
I wouldn't say 22GB was a small amount of usage!
James
Your billing period had just been reset. Between 6-8:30am.
caulbox
But the VMBU at 6.00 a.m. clearly stated that what I was then observing related to this month's usage (Nov 22 - Dec 21). I did speculate later that there might be some glitch overlapping with last month's usage, but my (blue bar) off-peak usage for the whole of last month amounts to only 17.14GB. I'm sure you can understand why my worries were compounded when I further viewed the breakdown of the 22GB, which makes no sense at all, and is a physical impossibility? I wouldn't want similar errors (or glitches) ever to relate to my chargeable usage allowance.
Fixes: 162
The breakdown isn't 100% accurate, as we've stated previously and I believe it also says on the page. The total usage will be correct however occasionally types of usage get misclassified and fall into other areas.
The reason it was still showing at 6am is that we can't reset everyone's usage at exactly the same time, therefore it's staggered over the early morning hours.
 Chris Parr
 Plusnet Staff
caulbox
OK thanks Chris.
