Fibre speeds
- Re: Fibre speeds
- « Previous
- Next »
Re: Fibre speeds
14-12-2011 2:36 PM
and in turn, you sending me a 'test' Zyxel NBG4604 router, so i can confirm that the box you sent me is unable to stream data over wifi, on any channel, at even G speeds, let alone N.
dick:blue Excessive emoticons removed as per forum rules
Re: Fibre speeds
14-12-2011 5:59 PM
If so then I guess I will wait!
Ta
Re: Fibre speeds
15-12-2011 9:24 AM
Waiting until Friday, before i start raising official calls, which is basically a waste of everytimes time.
Re: Fibre speeds
15-12-2011 10:57 AM
If the WNR1000 is faulty then the best way to check that is to send you another one of those.
Jojo
Re: Fibre speeds
15-12-2011 10:59 AM
Ok, I'll leave the order as it is then.
Jojo
Re: Fibre speeds
15-12-2011 11:15 PM
My laptop has an Intel Advanced N-6205 dual band 2x2 wifi adapter which would be a lot more compatible with the ZyXEL and hopefully utilise the 300mbps wifi speed. I have to set the WNR100 wifi to 54Mbps to get a reliable connection even when I'm within a couple of feet from the router.
BT Speed test results with wifi connected to the Netgear WNR1000 show 20 - 25Mbps while my gigabit ethernet adapter attains about 37Mbps.
If you're looking for a ZyXEL NBG4604 tester I'm your man.
Re: Fibre speeds
16-12-2011 9:50 AM
They know which products work execellent, they know which products work super fine, they know which products WORK............ and they know which products just about work and are budget options (despite having a good brand name)....
Hence we get the WNR1000 (which is a £20+ vat) Budget router....
At least i know my reason for changing providers in 14 months when i get asked
Re: Fibre speeds
16-12-2011 1:19 PM
I'm new here and maybe I'm just being paranoid but I don't seem to get answers or resolutions when I post questions.
Looks like the FTTC rollout testers get all the Plusnet staff attention.
Oldjim did make an observation about one of my posts more than a week ago but my Plusnet Current linespeed profile is still set at 26Mbps and my BT speed tests show speeds between 35 & 37Mbps. I don't know if this matters but I wonder if it can affect downloads etc.
My other posts are ignored or not followed up, I thought that part of the forum's function was a first line of support for less urgent queries before raising a ticket where necessary.
Re: Fibre speeds
16-12-2011 3:31 PM
Quote Is there a clique on this forum?
Not at all. Matt's answered your other post about this here: http://community.plus.net/forum/index.php/topic,100245.msg855395.html#msg855395
Re: Fibre speeds
17-12-2011 8:47 AM
Re: Fibre speeds
29-12-2011 1:35 PM
Hope you had a good xmas.
Any news on my new router?
Re: Fibre speeds
29-12-2011 2:22 PM
- « Previous
- Next »
