Fibre speeds
- Fibre speeds
Fibre speeds
24-10-2011 3:20 PM
I know it may seem like all i do is complain about my speeds, and i really am genuinely over the moon with my fibre speeds. But I've just seen mentioned in another thread that the fibre speeds are capped a little.
However, i was curious as to what the caps are for. Just an example, the bt infinity check shows i should be getting an estimated 32MB down, and 10Mb up. upon installation the engineer suggested and later confirmed that due to the distance i am from my cabinet i should expect to get the full 40Mb, and his tests showed the line getting 40mb.
My plusnet profile is set to 37mb, and i'm getting 33mb for the most part. My upload is 2mb. It is still within the first 10 days, so could this potentially change?
To clarify, i'm in no way complaining. I'm just curious as to where the other 7mb is going, it seems crazy for there to be 7mb that i'm not harvesting.
Is it a case of: plusnet set the profile based on the estimated line speed, rather than the actual speed?
Re: Fibre speeds
24-10-2011 5:29 PM
But, I'm not sure that that is a true indication of a rate that is sustainable over time and the various automated optimization strategies come in to play.
My installation has settled down with a downstream sync rate of 34284 with a SNR margin of 5.8dB I'm about 600metres away from the cabinet.
I got a "spare" VDSL modem off Ebay and have enabled the web interface on that so that I can monitor "true" sync rate.
A useful link - http://huaweihg612hacking.wordpress.com/ if you want to find out more...
Re: Fibre speeds
24-10-2011 6:00 PM
Re: Fibre speeds
24-10-2011 6:05 PM
Re: Fibre speeds
24-10-2011 6:06 PM
Re: Fibre speeds
25-10-2011 10:41 AM
from the download speed side of things, why is the PN download speed reduced a little (my neighbours are with BT, and get a 38mb down pipe), i'm on a 38mb ip profile, but level out at 33mb.....
i'm around 100m from the cab (i can throw stones at it!)......
I dont care that much to be honest about the speed difference between PN and BT users, just curious as per the OP, as to where the extra speed bit goes!
Re: Fibre speeds
25-10-2011 12:04 PM
Without direct access to your VDSL modem it's difficult to know exactly what's going on.
As I said above the BT engineer synced at 40mbs here on installation but I now sync at around 33-34mbs (33,760mbs this morning)
BT show a profile of 33,439mbs on their speed tester -but- my Plusnet profile shows as 20mbs as this was a trial install and I never had it updated.
From BT SIN 498 Issue 3.2
"At 1532 byte frame size 40Mbit/s VDSL will support 39.282Mbit/s Ethernet throughput."
And "The CP (Plusnet) is expected to shape the downstream traffic to match the actual VDSL2 line
rate in order to avoid excessive traffic loss.
So it could well be that Plusnet are overly aggressive with their traffic shaping/profiling...
Re: Fibre speeds
25-10-2011 2:14 PM
During the FTTC trial, we found that the maximum thoughput obtainable was no greater than 37000Kbps.This is why we set the speed to 37000. The maximum sync rate is 39999Kbps with about 9-10% lost to overheads.
As for the upload, we are looking to make it available up to 10Mbps but not sure when yet.
Jojo
Re: Fibre speeds
25-10-2011 2:15 PM
Quote from: Joanne Hi StuartUK35,
It's not a 'cap' as such. The BT profile will be setting our profile, so the line is probably performing a little less than your neighbours.
Jojo
Re: Fibre speeds
25-10-2011 2:17 PM
Re: Fibre speeds
25-10-2011 3:14 PM
For the record, i'm really pleased with my fibre. I was running at around 1.5 mb before June, then for some reason it dropped to 200k. I had an open ticket for aroudn 4 months (everybody at plusnet were incredibly helpful) and the problem was eventually resolved. a couple of weeks later fibre became available.
If you can imagine that, going from 200k to around 33Mb....
I'm very, very pleased. Was just curious.
Thanks again.
Re: Fibre speeds
25-10-2011 9:22 PM
Quote from: Joanne During the FTTC trial, we found that the maximum thoughput obtainable was no greater than 37000Kbps.This is why we set the speed to 37000. The maximum sync rate is 39999Kbps with about 9-10% lost to overheads.
Jojo
According to the BT tester the maximum profile on FTTC is 38, PN's is 37 but the difference is too small to quibble about.
A increase in the upload speed would be useful though.
Re: Fibre speeds
26-10-2011 9:55 AM
Quote from: Matt @knowdice I've just upped your profile to 30000 to better match the sync you're seeing, hope it improves things for you.
Hi Matt,
That didn't really help....speed test now comes in at 28,000 or lower vs previous 32,000ish
I always thought that the trial 20,000 was a "place holder" that set a maximum profile of FTTC rather than an actual profile limit.
Can you change my profile either back to 20,000 (which may not work the same as it did previously) or say 33,000 as I have a physical sync of 34,284
Richard
Re: Fibre speeds
26-10-2011 10:06 AM
I've just moved that to 33000. Let me know how it goes.
Jojo
Re: Fibre speeds
28-11-2011 5:37 PM
I have raised a ticket (49217837) but it hasn't been picked since Friday
BT are showing my download profile as 38715 so could you set my Plusnet one to match please.
Also, my upload seems to have gone astray should be 10mbs (I was on the trial) but seems to have been set down to 2mbs since some time after 1st November
