Fibre checker showed fibre , now no fibre
- Re: Fibre checker showed fibre , now no fibre
- « Previous
- 1
- 2
- Next »
30-11-2012 5:02 PM
I think you are getting confused by the situation before PN launched the new FTTC products as account types in their own right.
Message 16 of 20
(290 Views)
30-11-2012 6:15 PM
Hi
Thought I would check as its on the plusnet site http://www.plus.net/fibre-broadband/ on the right hand site when reading fibre package FAQ's
Graham
Quote If you're already a Plusnet customer
If you can get it in your area, you'll be able to upgrade to a fibre connection through our Product Change tool.
You'll need to change to either a Plusnet Value or Extra service to upgrade to a fibre service.
Graham
Message 17 of 20
(290 Views)
03-12-2012 1:26 PM
That means that if you request a product change to either Value Fibre or Extra Fibre we'll automatically place an upgrade order for you. I'm afraid we can't order fibre on your current account type.
Message 18 of 20
(290 Views)
03-12-2012 1:32 PM
Surely the FAQ should be amended to
Quote You'll need to change to either a Plusnet Value Fibre or Extra Fibre service to upgrade to a fibre service.
Message 19 of 20
(290 Views)
04-12-2012 11:43 AM
See what you mean and I can get a task raised to the web team to get that looked at, but by the same token if you visit the product change page there's only four options - Value, Extra, Value Fibre and Extra Fibre. That being the case I'd like to think most people who wanted fibre would choose the right ones... not that I don't see your point.
Message 20 of 20
(290 Views)
- « Previous
- 1
- 2
- Next »
