Fibre broadband drop out
Bridiebabes
Hi everyone recently my connection drops out a few times a day, I have Plusnet hub 2 and when it drops it flashes orange then few minutes pass and it reconnects. It's becoming more frequent.
Things I have done turned router on and off.
Factory reset.
Checked broadband socket.
Changed micro filter.
Possibly line fault?
Thank you
54 REPLIES 54
pvmb
Seasoned Pro
Fixes: 12
Re: Fibre broadband drop out
Assuming you are on FTTC...
Do you still have a landline phone? If yes then have you listened to the line using the Quiet Line Test (Dial 17070 Option 2) to check for crackling noises?
Or tested your line: Text 'PHONE <line number>' to 07800 008121
Bridiebabes
Morning unfortunately not, it's just the broadband only package.
I did text help but I think where I don't have a phone line it can't be checked
Fixes: 357
@Bridiebabes If you are on SOGEA, a screenshot of your connection status page, as in the  picture below, is useful. Please. Obscure personal details, though.
Fixes: 357
@Bridiebabes Sight of this page would also help, please:
Bridiebabes
Sorry how do I add screenshots like that?
Bridiebabes
Fixes: 357
@Bridiebabes Thanks for that. Assuming you are on FTTC, please follow the below - you have a major issue.
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
The above assumes you still have 'normal' landline connection - if you have a SOGEA (internet only) one, just use the second link to report a network issue.
Bridiebabes
I don't have a phone line this is broadband only package. I shall report now thank you
Fixes: 357
I think that is mentioned in my post - yes.
Bridiebabes
I tryed this yesterday by texting help to that number, all I got was we was unable to match this mobile number with a Plusnet account etc
Fixes: 357
Ah - a well known issue.All you can do is all them up - 0330 123 9123.
Bridiebabes
Will do that thank you for your help been great 😃
willcutforth
Fixes: 113
@Bridiebabes I can see you contacted us the other day. Did it all get sorted?
 Will Cutforth
Bridiebabes
I spoke to someone on the phone who was going to do a test down my line, they passed it to someone higher up as they couldn't complete a test. Still waiting to hear back on the results
Thank you
