Fibre and speed....
pvmb
Aspiring Champion
Fixes: 15
Re: Moved package.
@Andy2020
"Hi there, Landlines are ending Jan 2027... and I just stayed with Plusnet when I should have moved to a provider that does voip."
Or you could have done both! Though, from your posts I see you would likely have been less than interested in undertaking this yourself.
Andy2020
Re: Moved package.
I did get that email.. but I have a static ip and wanted to keep that hence staying with plusnet. Not many providers do a static ip.
But business.bt do a static ip also do voip which is included in the package.
Fixes: 479
Re: Moved package.
Moderator's note:
Topic merged. Please note that cross posting causes nugatory work and is against Forum rules
Fixes: 479
Re: Moved package.
Moderator's note:
Thread moved from My Order to Broadband
Andy2020
Re: Moved package.
Probleme hopfully solved tomorrow (Thursday) made contact with plusnet this afternoon and it was when I asked to remove my phone service and keep my broadband package I was put on a slower speed package. This is the third time I phoned regarding the speed problem so I don't if it was plusnet or openreach that caused it but I will see if it's sorted tomorrow and back upto the speed before first contact to remove phone line.
ExForce9
Seasoned Pro
Fixes: 5
Re: Moved package.
@Andy2020 wrote:
... made contact with plusnet this afternoon and ...   ....   ... I was put on a slower speed package.
That seems like a B.S. excuse from support to get you off the call - as it makes no sense, and sounds like they were agreeing with your speculation of incorrect provisioning in order to shut you up, rather than bother attempting to diagnose a fault on your line.
When you were on FTTC you claim your speeds were 46/16Mbps
after converting to SOGEA you then said your speeds were 18/4Mbps
That means for your original 46/16Mbps speeds, you must have been on Openreach's 80/20 line profile.
The ONLY lower speed tier that Plusnet provision SOGEA is 40/10Mbps, but if you had been moved to that then your speeds would be 39/10Mbps (NOT 18/4Mbps).
Similarly, if Openreach had put you on the wrong profile (which has never been seen before on this forum for VDSL),
the Openreach VDSL profiles are -
  • 0.5/0.5 Mbps  (voice only lines)
  •  18/2 Mbps  (obsolete)
  •  40/2 Mbps  (ended 24th April 2025)
  • 40/10 Mbps
  • 55/10 Mbps
  • 80/20 Mbps
NONE of which correspond your currently reported 18/4 speeds.
You still have either a line fault either externally or in your home, or the FTTC cabinet DLM has banded your connection.
Andy2020
Re: Moved package.
This could be an answer. Getting a bit fed up now with this.   This was the speed from router this morning.
Fixes: 479
Re: Moved package.
@Andy2020
Did you try this previous suggestion: https://community.plus.net/t5/Broadband/Fibre-and-speed/m-p/2058378#M377295
Re: Moved package.
@Andy2020
rather than a speedtest result consider sharing >Advanced  >Status >DSL line status section.
ExForce9
Seasoned Pro
Fixes: 5
Re: Moved package.
@Dan_the_Van
Looking at the attached image on Message #22, it appears that the router being used is a TP-Link Archer VR2800
I did have a quick look through the VR2800 "User Guide" , and couldn't see where that router's DSL stats could be viewed.
Re: Moved package.
@ExForce9
I've used TP-Link devices for years, so you get to know stuff. This is what it will look like
Clearly in the image there is no active connection
ExForce9
Seasoned Pro
Fixes: 5
Re: Moved package.
@Dan_the_Van
So to help @Andy2020 provide us with a screenshot of that, what are the TP-Link menu navigation steps to get there ?
Re: Moved package.
@ExForce9
Maybe I have already?
@Andy2020  in case you missed it as well in my first post on the thread
"consider sharing >Advanced  >Status >DSL line status section."
Andy2020
Re: Moved package.
Hi, Found it on my router, the DSL part. uploaded snapshot..
ExForce9
Seasoned Pro
Fixes: 5
Re: Moved package.
@Andy2020
It appears that you have two problems !
Those "Current Rate" numbers confirm that you are indeed provisioned on 40/10 Mbps, when you should be on 80/20 Mbps.
As your connection was supposed to be regraded today,  if it still looks like that tomorrow, then reboot your router, check those numbers again, and if they are still 9999/40000, then you need to get back to Plusnet support and get them to change the profile from 40/10 to 80/20.  While that won't get you to 19999/80000, your line speed should be closer to 12500/52500 Kbps.
Your second problem is that there is something wrong with however you are running your speed tests.
With your router's connection at it is currently showing, a speed test via an ethernet cable should be about 36/9.7 Mbps.
As you are only seeing 18/4 Mbps, you need to find a better way of doing speed tests using an ethernet connected computer and at a time when nobody else is using the connection.
