Fibre & phone scheduled to be installed Monday - a few questions
- Re: Fibre & phone scheduled to be installed Monday...
- « Previous
- 1
- 2
- Next »
Re: Fibre & phone scheduled to be installed Monday - a few questions
26-02-2013 12:13 AM
26-02-2013 3:00 AM
Quote Estimated line speed:
2.0Mb (Accurate to within +/- 1Mbit) - Checked on 2013-02-25 17:17:21
Current line speed:
14.2 Mb
Cheers,
Tony
26-02-2013 3:48 AM
Before heading off to bed I've done a few more tests (after doing a 'soft' disconnect, wait a few minutes then reconnect to internet) when most of the UK internet is sleeping - 3:30am.
BT Wholesale:
Download speed achieved during the test was - 13.41 Mbps
For your connection, the acceptable range of speeds is 16 Mbps-77.44 Mbps
Additional Information:
IP Profile for your line is - 77.44 Mbps
Upload speed achieved during the test was - 12.96Mbps
and…
This was on ptw-ag01. Wired connection to router.
The only other information that may possibly be relevant is that I appear to still be on a fixed IP left over from my ADSL at my previous address.
Many thanks for your perseverance. Good night.
Cheers,
Tony
26-02-2013 8:50 AM
You could either wait for one of the Digital Care team to pick up this thread and sort it, or log the problem at http://faults.plus.net/
26-02-2013 10:17 AM
I think I'll wait a few hours before contacting PN, so by then it's been active for at least 24 hours.
However, if someone at PN Towers decides to tweak a setting / unplug the kettle in the server room / install a fatter cable / or whatever before then I'd be extremely happy.
Cheers,
Tony
26-02-2013 10:52 AM
I've manually adjusted tour profile to match your new sync speeds so you can now enjoy them
Let me know how you get on.
26-02-2013 11:12 AM
This is a smidgen better…
Now, during the install the BTOR engineer showed me that my speed would be 80/20 - can I have that now? I was tempted to point out that I'd probably have to be sitting inside the cabinet for that!
I'm now a very happy bunny.
All the very best.
Cheers,
Tony
26-02-2013 11:26 AM
New test:
Interesting to see that the difference between wired and wireless is so small.
Many thanks everyone.
Cheers,
Tony
26-02-2013 11:31 AM
http://www.speedtest.net/results.php?sh=539333fd781a95d0bfab80c8b46f8bb6&ria=0
I had a lovely dip on the 17th Feb to 26Mb but changing gateways fixed that.
The speed seems to vary as well, upload getting faster (+/- 3Mb) and download slower (+/- 10Mb/s) but overall nice to have.
You must have been quite close to the router when you did the first test?
26-02-2013 11:47 AM
26-02-2013 12:43 PM
26-02-2013 3:49 PM
Use the user tools gateway checker (http://usertools.plus.net/@gateway/) to see what you are on/moved to, if you get the same on, re-disconnect and try again.
- « Previous
- 1
- 2
- Next »
