Faulty micro filter caused Sync speed to drop
- Re: Faulty micro filter caused Sync speed to drop
29-08-2009 10:04 AM
See para What is "Adaptive Max Logic"? at http://kitz.co.uk/adsl/IPprofile.htm
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
29-08-2009 10:22 AM
My speed initially dropped to 1462 and is now 7264 - by the information on that site I should be back to normal now.
29-08-2009 10:28 AM
I have never seen less than 3 days
29-08-2009 11:09 AM
So I'll hope for a return by this time tomorrow then.
29-08-2009 2:19 PM
29-08-2009 5:09 PM
I'd hate that. How did you know you just needed to wait longer and that it wasn't the BRAS profile being stuck?
29-08-2009 5:38 PM
29-08-2009 5:48 PM
29-08-2009 6:22 PM
Jul 18, 19:00 6673 kbps (834kB/s) 380 kbps (47.5kB/s) Share
Jul 18, 14:27 6311 kbps (789kB/s) 380 kbps (47.5kB/s) Share
Jul 17, 12:24 466 kbps (58.3kB/s) 368 kbps (46kB/s) Share
Jul 16, 18:31 473 kbps (59.1kB/s) 381 kbps (47.6kB/s) Share
Jul 16, 11:37 465 kbps (58.1kB/s) 380 kbps (47.5kB/s) Share
Jul 16, 08:08 478 kbps (59.8kB/s) 381 kbps (47.6kB/s) Share
Jul 16, 07:37 461 kbps (57.6kB/s) 379 kbps (47.4kB/s) Share
Jul 16, 07:37 674 kbps (84.3kB/s) 382 kbps (47.8kB/s) Share
Jul 15, 15:22 457 kbps (57.1kB/s) 381 kbps (47.6kB/s) Share
29-08-2009 7:48 PM
29-08-2009 8:53 PM
That is quite normal and nothing to worry about
30-08-2009 3:10 PM
30-08-2009 3:19 PM
30-08-2009 8:44 PM
30-08-2009 8:54 PM
