FTTC installed - how long before speed increases?
- Re: FTTC installed - how long before speed increas...
28-01-2014 10:02 AM
The engineer has been and gone, FTTC installed - but speed tests seem to indicate im stuck at 10mb. Dos anyone know how long it may be until I should se this pick up?
Also, how can I see the sync speed on the plusnet fttc router?
Many thanks in advance
Re: FTTC installed - how long before speed increases?
28-01-2014 10:39 AM
28-01-2014 10:51 AM
There is, yes - basically due to last night's maintenance, the account change script hasn't run yet so your account still thinks you're on ADSL2+. I'm chasing this for you now, I'll update as soon as the change is done.
As for the sync, unfortunately you can't see this in the router as it's the modem that makes and maintains the connection to the exxchange.
28-01-2014 12:04 PM
If you could let me know when the ip profile has been reset that would be much appreciated. Upload now on a wired connection just over 18mb, so at least that should improve the working from home speed
28-01-2014 12:10 PM
28-01-2014 12:14 PM
28-01-2014 12:19 PM
Your help is much appreciated
28-01-2014 1:10 PM
Quote from: Oldjim why 21,000 surely if he is on 80/20 with almost full upstream speed it should be 79,000 or can't you do that when the system thinks he is still on ADSL2+
The latter. Believe it or not, if I could have upped the speed to 80000 I would have
28-01-2014 1:28 PM
28-01-2014 1:33 PM
@adambro your account type has changed already, I've bumped the profile for you - hope it's improved things?
28-01-2014 1:43 PM
28-01-2014 2:12 PM
28-01-2014 3:53 PM
28-01-2014 4:28 PM
Can confirm that's done the trick for me. Now getting around 55Mbps down which fits with what I was seeing for the BRAS profile. Thanks again.
28-01-2014 5:10 PM
No pressure.
