FTTC but DL 3.5mb (ul is 17mb!)
ivankb
Re: FTTC but DL 3.5mb (ul is 17mb!)
Well that showed it.
I connected via my PC directly and got a ~78mb DL!
Then without doing anything else plugged my router back in and tested again and ~72mb DL...
So no idea but all is good.
Thanks to all very much!
Pettitto
Fixes: 5
Thanks for letting us know that.
Just out of interest, how and what equipment did you have set up when you were getting the lower speeds?
ivankb
Same router that is now setup and getting the higher speed, it's a "Buffalo AirStation Nfiniti"
So nothing different at all from what was getting the 20mb.
Fixes: 402
The two pppoe disconnects/reconnects could well have put you on a different gateway. There was a problem with ptn-ag01 yesterday.
ivankb
At the moment I'm on:
You are currently connected to gateway pcl-ag02.
Dhaos
Yeah last night i was going to mention about switching gateways to see if that changed anything, but switched to much can have a bad effect on your ip profile.
ivankb
Hi
All was good for a few days until Saturday, then the connection dropped for a while and when it reconnected the speed is down to ~4mb.
Still with the fast upload.
At the moment I am on gateway:  pcl-ag03
Ivan
ivankb
Quote from: Kelly
There will be line training, but that is about bringing your line down to a stable speed.
This smells like a fault to me!  Chris and/or Chris will be investigating for you.
Hi Kelly
I seem to have an issue again, please see what you can.
jelv
Fixes: 10
Have you tried disconnect/connect of the router to see if a different gateway is better?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
ivankb
Hi
Yip, I have rebooted the openreach router several times, seen gateways 1,2,4,5
Always the speed is ~4mb now though.
jelv
Fixes: 10
To change gateway it's just the Plusnet router not the OpenReach modem!
ivankb
Quote from: jelv
Ok, either way it hasn't helped.
chrispurvey
I'd suggest running through our faults checker at http://faults.plus.net and we'll take a further look into this.
ivankb
Hi
Done thanks.
Pettitto
Fixes: 5
I've just popped an update on the Fault ticket you've raised.
