Broadband speed
Timeoutgang
Broadband speed
My contract states that I should be getting speeds of 38-40 mbps, however, I have never been close to getting this (maximum speed I've ever had was 28 mbps). Wasn't a problem previously, however, since myself & my wife are now working from home & are using the Internet constantly for work, it has become an issue. Could someone please look in to this?
2 REPLIES 2
Fixes: 384
Re: Broadband speed
@Timeoutgang Welcome to the forums. As staff response on here can be a little slow at times, it may be an idea to give other Community members a chance to see if they can spot anything out of place.
BT Broadband(obscuring your phone number) and BTW Performance Tester - Over a wired (ethernet) connection if at all possible, please report the 'ADDITIONAL DIAGNOSTICS', and sight of the broadband connection status from your Hub (with the 'Username' obscured) would be a good starting point.
For the Hub One -
For the Hub Two -
If phone test is OK then take the front off your telephone master socket, you may need to remove two screws. In behind you will find the test socket. Plug a filter in here and connect that to your hub. If it’s still dropping out then report a fault at https://faults.plus.net.
adamwalker
Fixes: 223
Re: Broadband speed
Hi there @Timeoutgang, I'm sorry that your connection speeds haven't been up to scratch. I've just been looking into this on our side and line tests aren't showing signs of any issues at all. Assuming all your devices connect over WiFi it would be worth running a wireless channel scan on the router to make sure it's connecting to a frequency that avoids interference.
If you like I can log into the router from here and do that for you, I just need to ask for your approval first as it will cause the wireless signal to drop out temporarily for about two minutes.
Adam
 Adam Walker
