FTTC DLM Profile
- Re: FTTC DLM Profile
FTTC DLM Profile
22-07-2013 11:44 AM
Has there been any recent change in the default profile?
Is there any way for a customer to request a specific profile?
22-07-2013 3:26 PM
The default for all our connections is standard stability, it's never been changed as far as I'm aware, and yes - either by ticket or posting here
Hope that helps.
22-07-2013 5:58 PM
I'd like mine changed to Speed. I have submitted a support ticket.
23-07-2013 12:26 AM
23-07-2013 12:50 AM
What gives? I'm fairly certain BTW options include a 'Speed' profile.
23-07-2013 8:25 AM
23-07-2013 9:53 AM
So, by default we do supply customers on the fastest profile available.
23-07-2013 9:58 AM
I don't recall anything from the FTTC trials (certainly not the 80/20 trials).
Any info on the (speed) impact from the increased stability options?
23-07-2013 10:18 AM
Basically the more stable options tighten up the error and reset margins, so where say 10 resyncs a day would cause the SNR to be raised on a standard connection, maybe 2 would cause the same on a line set to super stable. The speed changes seen would be the same as on the other options (so around 800kb/s for a 3dB rise in the SNR target) but would be more likely to happen.
Again, not totally sure of the margins even for ADSL let alone Fibre, but that's how it works. Several of our business customers have opted for Stable or Super Stable lines as that's more important to them than getting the fastest connection possible.
23-07-2013 10:49 AM
23-07-2013 11:00 PM
23-07-2013 11:49 PM
The standard, stable and super-stable service options are nothing to do with that. You should be on the standard (speed) option, but should be able to choose stable or super-stable if you wish. Either of the latter is likely to reduce sync/line speed (unless you are very close to the cabinet), but your traffic will still transfer at the resulting line speed.
14-10-2013 10:44 PM
Quote from: Matt Sorry should have clarified. "Standard" *is* the "Speed" profile, the only other two options we have are "Stable" or "Super Stable".
This thread has been brought to my attention tonight. Can I just ask if someone from Plusnet can clarify something for me and double check what profile Plusnet are placing their FTTC customers on.
The options mentioned above ie Standard, Stable and Super Stable relate to BT wholesale ADSL provisioning. GEA FTTC does NOT have a super stable profile
Confusing I know.. but to recap
BTw ADSL profiles =
Standard, Stable, Superstable
BTor FTTC profiles =
Speed, Standard, Stable.
If you are provisioning GEA (FTTC) as standard, you are selecting the middle profile & not speed. You wont be the first ISP who has been caught out by this.
I could name another respected UK ISP who for the past year or so thought by using 'standard' their customers were on the fastest profile and its only recently come to light that they werent. Its a perfect example of how confusing the profile naming between the 2 products are when it comes to the ISPs ordering from Openreach.
You can see here the 3 FTTC profiles.. and that a customer provisioned as standard, will in fact be on the middle profile.
TIA
14-10-2013 11:52 PM
15-10-2013 7:04 PM
So... Bump
