Exchange Status Checker
- Exchange Status Checker
Re: Exchange Status Checker
31-10-2009 3:01 PM
01-11-2009 12:02 AM
01-11-2009 9:27 AM
01-11-2009 9:40 AM
01-11-2009 9:48 AM
The date you see is the last date the status for that exchange changed. The CSV import file does not contain an update for event exchange very time. Sometimes exchanges are only included when something changes. As usual BT (Not BTW) are inconsistent with their supplied information
Re:Exchange Status Checker
02-11-2009 12:57 PM
This isn't something that we've forgotten. We're trying to find a way of automating things and once we do, it'll be updated regularly.
Bob is still on the case.
02-11-2009 1:06 PM
07-11-2009 5:29 PM
Quote from: tonycollinet Where do you find out when it was updated. The only date I can find for my exchange is "last updated 3 March 2009" which if this is the last update puts it 6 months out of date.
You need to go to the VP status page to see when the record was last updated. Currently it seems as though it was 18th September. Oh dear
Maybe Bob could give us an update on the situation.
07-11-2009 9:56 PM
It obviously hasn't occurred to them that they could continue running the process the same manual way as it has always been done until the improved process is available.
09-11-2009 2:18 PM
Simple fact is that Phil is too busy with BSC work to find the time to get it done, and it takes a fair time to do it manually since BT made some changes a while back.
09-11-2009 2:20 PM
Quote from: jelv I don't want to see it removed, but out of date/misleading information is worse than no information.
09-11-2009 2:21 PM
Quote from: jelv If someone raises a speed fault and it appears that the IP Profile etc is all fine so it could be down to congestion, is the exchange status one of the things the agents check for? If so where do they get the information from?
Any chance of an answer to this question?
10-11-2009 10:25 AM
10-11-2009 10:27 AM
10-11-2009 10:09 PM
