Plusnet Hub 1 wifi guest password?
Pietro25
Is there any way to set up a guest wifi password on the Hub One without changing the primary one.?
3 REPLIES 3
Fixes: 334
Re: Plusnet Hub 1 wifi guest password?
@Pietro25 I may be wrong here, but I don't think the Hub1 supports a guest network.
Fixes: 457
@Pietro25
@jab1  is correct, there is no guest network capability in either the Hub One or Two.
Pietro25
Thank you to those who replied.
